Duel battery hookups
Discussion in 'The Garage' started by Hustler, Jul 21, 2005.
  1. Hustler
    Hustler 1/2 ton status
    May 14, 2001
    326
    St. Peters, MO
    I know this has been talked about in the past, but can someone tell my what is the best way to hook up 2 batteries and why? Thanks.
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    im just going to buy the battery cables for a diesel... running in parallel.....already have the tray in the truck... and second battery sitting there... :wink1:
    my stock 63amp alt will do for now... however when that ramsey patriot 15k comes in.. I have a feeling that I am giong to have to re-look at the 140 amp alt upgrade I was doing.... :doah:
  3. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Alot of ppl like to buy the battery tray from a diesel and put it in their truck. All the wire needs to do is go positive to positive and ground both batteries.
    The advantages.......better starting......cold cranking amps.
    Won't run down as fast when using a winch.
    If one battery goes out, you still have another :D
  4. airbornesoldier327
    airbornesoldier327 1/2 ton status
    Feb 11, 2005
    134
    north carolina
    I thought about doing the same, but since i run a winch and KC Daylighters, i prefer to isolate each of the batteries from each other, so i can put all the other stuff on the other battery, liek the winch, lights, CB, and so forth on one, and use the other battery for starting the truck. That way if i burn out the one i can still start the truck. Thats just me though! :D
  5. RootBreaker
    Nov 29, 2001
    5,117
    173
    that is why you get one of those energizer batteries with the twist top switch... remember that battery? if it dies... switch and it is like 2 batteries in 1..... :wink1:
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Go here and read all... www.hellroaring.com
    Been runnin this setup for years and years..works great!
  7. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Agreed. I've got one sitting in my shed waiting to be installed. :waytogo:
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I prefer simple. I used a Marine combining switch like this one from West Marine.
  9. airbornesoldier327
    Feb 11, 2005
    134
    north carolina
    Thats the system i have set up in mine, but i bought it and pieced it together through pep-boys and napa... and on that note i wish i woudl ahve gone through those guys. Looks liek i would have saved myself some money! :D
  10. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i got the kit from painless, like it alot
  11. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    honestly man, do a search.. this has been rehashed a billion times, should find tons of stuff...
    that being said, i'll be going with the straight foward marine battery switch, no selinoid.. almost as parts free as just running parellel... which i like.. and i already have the switch...
    i'm sure the hellroaring, isolators, selinoid, etc are a nice setup.. heck, 75% of the boats i work on run isolaters.. but i'm just going the simple route...
    heres a couple diagrams i've snagged over time from here for ya that may help....
