duel tank wiring problems
Discussion in 'The Garage' started by socalslider, Jul 24, 2006.
  1. socalslider
    socalslider Registered Member
    Jun 21, 2004
    71
    Oceanside Ca
    The PO did some funky things to the wiring to the duel tanks, including add an electric fuel pump, my problem is that only one tank works.
    anyone got a diagram?
  2. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    What year?
  3. socalslider
    Jun 21, 2004
    71
    Oceanside Ca
    that might help, 79, :doah:
  4. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    This might be kind of similar. It's a little newer with the in tank electric pumps, but it's the best I can do. Sorry.
  5. socalslider
    Jun 21, 2004
    71
    Oceanside Ca
    thanks for the reply, as it does help some, but I need to know the colors and what they do.
  6. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    You should have an individual ground to the frame from the tank for each side. Also a wire to the sender with a rubber end cap, fits over the sending unit stud. Look at your working tank and check for the same set-up on the non-working side. It's possible the ground wire came loose.
