duelly k5 blazers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nmud2deep, Sep 26, 2005.
  1. nmud2deep
    nmud2deep Registered Member
    Apr 23, 2003
    63
    georgia
    does anyone have a pic? i found a duelly front dana 60 i might wanna get and i might put 4 in the rear 14 bolt
  2. nmud2deep
    Apr 23, 2003
    63
    georgia
    anyone have any pics? i would also like to know if there is anything i have to change to duel the rear wheels
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You expected replies within 15 minutes?
    Just at a guess, you'll need a 1 ton dually 14FF rear axle and the spring hangers to inboard the springs to 1 ton width. Shocks would need some adaptation as well. That and a set of fiberglass "hips" along with some trimming aught to pretty much do it.
    You could also get the dually rear and run the Hummer double beadlocks without recentering.
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    you would also beat the living hell out of the axle flange with that set up.
  5. rooferbret
    rooferbret 1/2 ton status
    Dec 26, 2003
    265
    Sacramento,CA
    Are you saying that one way to run a 1-ton rear on a k5 is to change the hangers?
    The frame on a 1/2-3/4 ton is the same width as a 1-ton?
    If this is the case i should have gotten a 1-ton shakle flip as i was grinding rivits anyway.
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, it is a bit exposed, but not nearly like it would be on a SRW axle. And several people are apparently running that config successfully...
    And yes, the frames are the same width. The only diff is that the hangers keep the springs further inboard on the DRW trucks. If you are seriously planning on doing this, you should call Stephen, he might well work out a swap (assuming you mean ORD flips).
  7. rooferbret
    Dec 26, 2003
    265
    Sacramento,CA
    :doah: Yes i have a ord flip, So do you have to move the front one ton hanger closer? We need a tech article on this :D
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yes, you'll need a 1 ton front hanger. IIRC, the 2WD and 4WD are different "heights", so get the one you need if you do this.
    I don't think there are enough people interested in that for a tech article, but if you write one and post it for Steve, he might post it on the site if he things it's of value to members...
  9. nmud2deep
    Apr 23, 2003
    63
    georgia
    i would just wanna see some pics...anyone got any?
  10. nmud2deep
    Apr 23, 2003
    63
    georgia
    can i turn a dually dana60 to a normal dana 60? what would i have to do
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Swap the hubs. You even can buy new hub assemblies from GMPartsDirect.
  12. nmud2deep
    Apr 23, 2003
    63
    georgia
    cost wise for the hubs about how much...i am getting the d60 for $300 with matching 4.10s...how much does a good d60 go for?
  13. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    :eek1: LOL, no one is gonna talk to you now!
  14. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
  15. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    'Cause everyone will be jealous of his $300 D60, that's a steal!! A good Dana 60 goes for at least 1-2K or more, depending on how well it's built and with what beef ups.
  16. nmud2deep
    Apr 23, 2003
    63
    georgia
    i got the d60 from a guy that was builting a duelly jeep and than his wife gave him some pretty papers saying she gets half and i got the front end and a 15 foot hunting camper for $300
  17. nmud2deep
    Apr 23, 2003
    63
    georgia
    has anyone tried the jeep duelly thing and does anyone have pictures of a k5 duelly?
  18. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
  19. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    change the wheel bearing hubs to single wheel...instead of dually hubs..
