Dulley disc brakes ?
Discussion in 'The Garage' started by 85k5dsl, Jan 18, 2007.
  1. 85k5dsl
    85k5dsl 1/2 ton status
    Feb 23, 2006
    253
    Maryland
    I'm running a 14 BFF with the Dulley hubs and H1 wheels and would like to swap over to disc brakes. All of the kits I have see so far state not for use with a Dulley rear. Does any one make this or am I stuck with using drum brakes.
    Mark
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    How do your tires not rub the leafs? :crazy: Sounds like you have really narrow track going - especially with the backspacing on the H1s.
    These guys make a dually disc kit. I believe they are using a rotor with a very deep 'hat'.
    http://www.blackbirdscustomtrucks.com/index7.html#8dually
    Another way to go is a weld-on disc bracket. Or you could move or replace the stock backing plate flange so it will take one of the really cheap bolt-on kits.
  3. dremu
    Feb 27, 2000
    15,952
    444
    East of San Francisco
    The problem with the duallies, either C&C or wide, is that the brake flange is in the wrong place for the rotors to line up with the calipers.
    I ended up going totally custom -- Blackbirds didn't have the kit, IIRC, when I did mine -- with the rotors for a 2003 Express Van (DRW, disc) which are very very deep, but also a smidgen wider diameter than the K20 rotors most folks use, so I had to do totally custom weld-on brackets to hold ther calipers. I used the Caddy ones as I've had good luck with them.
    Pix on request.
    U2Slow, the 1-ton's narrow spring spacing is an advantage on my truck, i.e. the tires fit, but barely ... I ended up using SRW hubs, so it's the stock WMS (67"? I forget) ... but even with the DRW hubs that tuck the wheels in 2" more each side, it's doable.
    On a K5, though, with the wider spring perches, and assuming fat tires... yeah, could get close. Might want to switch to SRW hubs to widen the WMS.
    -- A
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I asked about this awhile back and someone linked me to a place that had a kit for duallies, AND I do remember that they were VERY proud of their product too,,,,,,just gonna keep the drums thank you :crazy:
  5. tvguy
    tvguy 1/2 ton status
    Jun 1, 2006
    143
    Duluth, GA
    I looked for a kit as well . . . for a Dana 70HD dually. Blackbird Custom was the only one I could find, but no way I could justify the price tag. Great Lake Off Road told me thier Dana 70 kit would work on a dually with '75 rotors and calipers, so I ordered it and went out and bought the rotors and calipers. A couple hundred bucks later and IT DOES NOT WORK! When I test fit the rotor in the stock budd wheel, there was only about 1/2" of clearance. When I emailed Shawn at Great Lake, he said he "didn't know I was using stock wheels" and suggested I buy new, larger wheels. Needless to say I scrapped the disk brake project and put the drums back on.
