Dum F---
Discussion in 'The Garage' started by mdapperdan, Mar 12, 2006.
  1. mdapperdan
    mdapperdan Registered Member
    Jan 15, 2006
    39
    Dewey Az.
    I'm replacing my heads on my stock 350 in my '74 blazer and was hoping that someone can direct me in valve adjustment. (some where so when I fire the motor it will be close to the proper valve lash adjustment.)
    Thanks Dan
  2. goldwing2000
    goldwing2000 Guest
    Assuming hydraulic lifters?
    Be sure to soak the lifters in oil, working the pump up and down a few times while they are soaking.
    Starting with the number 1 cylinder, rotate the engine until it is at TDC on the compression stroke.
    Tighten the rocker studs until the pushrods have zero play and then an additional 3/4 to 1 turn.
    If you're running mechanical lifters, tighten the studs until you have the proper cold clearance between the rocker and valve tip.
    Repeat for the remaining cylinders. The easiest way to do it is just to go in firing order (18436572) with the intake off and just watch for when both lifters are down.
  3. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    Get a Chiltons. Seems like getting tdc on the compression stroke on every cyl. is the trick to doing it the non-running way... Then maybe adjust to zero valve lash at that point? do-no for sure
    EDIT: Yea, what he said.
  4. wildmouse216
    wildmouse216 1/2 ton status
    Dec 26, 2005
    135
    Rifle, Colorado
    With the valve covers off and lifters having been thoroughly soaked in oil, set engine at TDC and tighten all rockers until you just barely can't turn the pushrods. Then turn crank to 1/4 turn and repeat. Back off any that need to be backed off. Then to 1/2 turn then 3/4 turn and so on to two full turns of the crank. By the end all will be perfectly adjusted and you will not have to adjust them while running. You won't have to guess at 3/4 to 1 turn more than this or that. An old Mechanic told me how to do this and it works really good.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    one full turn of the rocker nut past zero lash is what will center the plunger in the lifter body
    which is factory stock correct
    zero plus one is for all hydraulic lifters
    you want ot adjust a rocker when the lifter is all the way down in its bore and on the backside of the lobe of the cam that it rides on
    i like ot adjust mine before iput the intake on so then i can see where the lifters are at
    no readjustment necessary after zero plus one full turn
    good luck
  6. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    new lifters? screw trying to set them just by soaking them in oil. prime the oil pump.
  8. wildmouse216
    Dec 26, 2005
    135
    Rifle, Colorado
    You are not adjusting them to the one full turn past so they are not super tight when they are on the back of the lobe. What this does is adjust them when the valves are closed. The pushrods should center in the lifter body as soon as you put them in not while you are adjusting valve lash. By then it is too late.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i think you're misunderstanding what he's saying. he's not talking about the pushrods centering, he's talking about the plunger in the lifter centering in its bore (at "half stroke"). it doesnt matter if you're on the "front" of the lobe, or the "back" of the lobe, as long as you're on the base circle of the cam.
