dumb 14ff? and th400 ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nonesuch, Aug 23, 2001.
  1. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    what is the difference inbetween the 3/4 and 1 ton 14ff if there are any and is it possible to adapt a 2WD th400 to my 350/np241. the tranny came off a 454. i am aware of the weaker case but i need a trans soon and this one is rebuilt out of a wrecked truck for next to nothing!
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    The only difference between a 3/4 & 1 Ton 14B is that the spring perches and shock mounts are different, they are wider apart than on the 1 Ton. Can't help you with your trans question.
    Derf00
    "A WISE MONKEY NEVER MONKEYS WITH ANOTHER MONKEY'S MONKEY."
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    as for the trans question all you have to do is replace the output on the 400 and buy the addaptor plate for the t-case.
    it ends up being a lot of work, timewise. and you need to know a bit about a auto trans
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  4. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Get ahold of advance adapters for kit. Yea, plan on a day doing it, then another day figurin what you did wrong LOL
    If you ain't hurt, you ain't playin' hard enough.
    The General
  5. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    The difference between the 3/4 and 1 ton 14 bolts is that the 3/4 ton on is a semi floater and not as strong as the 1 ton 14 bolt full floater.
    Adam
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Well, not quite.
    The 14 full floater is available for BOTH 3/4 and 1 tons. And yes, the spring perches and shock mounts are in different locations than the other.
    The semi-floater you are talking about did not come into production until '81, and ONLY on the 3/4 ton trucks.
    So, in reality, the full floater 14 bolt for both the 3/4 and 1 tons are EXACTLY the same axle. Just the mounts and perches being different, thats all. The drums are also larger on the 1 tons.
    <font color=blue>"Ya don't have to beat it, ya know!!!</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
