Dumb Noob Tranny question
Discussion in 'The Garage' started by IGOR, Aug 10, 2006.
  1. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    So - I have the engine out of my 72 right now - is it possible to pull the tranny, transfer case, & crossmember as one unit? Or is it better to unbolt the tranny and pull it seperately?
    It doesn't look like it would be that bad - but the crossmember bolts to the top of the frame on the underside - and I can't see how to get the crossmember out unless it is twisted within the frame
  2. 88-3/4t-bad boy
    88-3/4t-bad boy 1/2 ton status
    Nov 27, 2005
    150
    Texas
    i recently had a friend of mine pull the clutch out of my suburban. what he did was pull of the driveshafts. put a motorcycle jack under the transfer case and the crossmember and unplugged the reverse indicator cable (he broke it) then he took some tow straps and tied it to the jack. the jack held for like a week then it slowly hit the ground. but i cant help you with the tranny never had to pull mine. just the bellhousing
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    all of mine I have pulled them out together. with your crossmember that way you will probablyhave to slide the whole assembly back to free up the tranny and motor then turn it sideways to get it to drod out. if not you'll need a 2nd jack to put under the t case ands one on the tranny pan then take the crossmember out then lower them both down. I'v always put em back in seperate though. Just always pulled them together.
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    In-n-out together, tranny jack and floor jack. Crossmember first out and last in.
  5. bigredblzr
    bigredblzr 1/2 ton status
    May 9, 2003
    151
    NORCAL BABY
    I think that it really depends on your equipment. If you've got a tranny jack, and a nece even surface, you could do it as one unit (but you'd have to remove the cross member first obviously). If you do it this way, it is alot less unbolting and rebolting everything together. However, if you do it this way it is also harder to line up the bellhousing to the back of the engine when you have to put it back in. It is also a little harder to manuever in general. I've always done mine piece by piece, however, I was usually working with just a floor jack and always on gravel (not fun).
  6. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    I had to pull mine separately due to lack of equipment. And I agree it might be harder to align the bell housing with the t case on there. If I could do it again (and I will once I get a doubler) then I would pull them together and reinstall separately.
  7. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    Okay - dumb question - but how do I get the cross member OUT of the frame - it needs to be twisted - it looks like
  8. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    most likely youll have to unbolt the tcase from the crossmember then support the setup off of the crossmember a good bit. from there you can probably play with the xmember enough to drop it.
