Dumb Q: I ferget how ta' Diag a fuel guage / sender ???? LOL
Discussion in 'The Garage' started by uglychevyZZ4, Dec 29, 2002.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Dumb Q: I ferget how ta\' Diag a fuel guage / sender ???? LOL
    ok, 87 burb, F.I. need to finger out if i have a bad guage or sender, and i forgot what to ground or give power to diagnose this? I am having a after xmas brain fart /forums/images/graemlins/grin.gif so tell me here like Im 5 years old /forums/images/graemlins/laugh.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Re: Dumb Q: I ferget how ta\' Diag a fuel guage / sender ???? LOL
    Grounding the sender wire should make the gauge read full.
  3. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    ok, i thought so, but wasnt sure /forums/images/graemlins/laugh.gif its been a few years /forums/images/graemlins/grin.gif
  4. BARRAZA
    BARRAZA 1/2 ton status
    Oct 17, 2001
    259
    USA
    I think its the other way around, grounding the sender wire will make it read empty.
  5. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    That'll test the guage assuming the wire leading to it is intact. To test the sender you will need a voltmeter of some sort. Either analog or digital. You can set it on its lowest Ohm setting to read continuity. One wire to the sender electrical terminal, and the other to the body of it somewhere such as the top mounting plate. Does not matter which polarity you use. Slowly swing float thru its travel while watching either the needle or the digital readout to see if you find a break in its flow/read out.
  6. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    got it, its the sender, can you believe that fuel guage sender for a tbi 350 is $ 379.00 /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif what a freakin hoseball crock o donkey dung /forums/images/graemlins/mad.gif /forums/images/graemlins/frown.gif
