Dumb Ques on Bellhousing
Discussion in 'The Garage' started by mudbog42, Mar 24, 2007.
  1. mudbog42
    mudbog42 1/2 ton status
    Jul 16, 2006
    452
    Florida for now
    Does the bellhousing hold engine oil or transmission fluid:dunno: , because my truck all of a sudden decides to start leaking oil:mad1: so I troubleshoot to try and find the leak :thinking: and I find a stripped out bolt on the bellhousing that just spins,:ooo: so i go to loosen it and oil drips from behind it:what:
    Could this be my leak or did I just find a bolt that needs to be replaced?:dunno:
    Thanks:bow: 86:usaflag: :k5:
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    Auto or manual?
    Your bellhousing doesn't hold oil, something is leaking.
    It could be the rear main seal (motor). It could be the input seal for the transmission too.
  3. mudbog42
    Jul 16, 2006
    452
    Florida for now
    Auto sorry forgot to mention that, its a 700r
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Shouldn't be any fluid in there. You now have two problems. Stripped threads on a bolt and a leak. If its red your trans is leaking. If its oil then your engine is leaking. Most likely culprit is the rear main seal. Degrease your engine if that is what's leaking so you can find the leak before you start replacing things that may not need fixed
  5. mudbog42
    Jul 16, 2006
    452
    Florida for now
    Yeah I just got the motor cleaned the other day to try and find it, its leaking engine oil but the main seal looks to be dry. Checked valve covers, they look dry, I just wiped it all down again and nothing yet but it seems to be coming somwhere between the valve covers and the bellhousing because that side of the motor keeps getting wet but I still can't pin point the leak
  6. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    longshot but check the back of the intake and the distributor gasket. ive had both of them throw me before.
  7. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    I'll put money on the intake gasket
  8. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Yep!
  9. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    oil pressure sender is there too,
  10. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Good point, Sometimes look over the obvious hunting a simple problem.
  11. resurrected_jimmy
    May 23, 2005
    2,241
    hadn't thrown it out there yet but that's exactly what I was thinking
