dumb question
Discussion in 'The Garage' started by big83chevy4x4, Apr 11, 2004.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    will a serpentine setup from a 92 4.3 fit an older 350. i think it does but not sure. also how is it routed with out ac? does it have a idler puller where the pump sits?
  2. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Cant answer all of it but the 4.3 is a 350 minus the middle 2 cylinders, so they might. /forums/images/graemlins/k5.gif
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Just like the setup on the late model 350, just make sure you get a reverse flow water pump and fan blade setup (ones from an 87 on up)
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Not sure if it is the exact same set up between 4.3 and 350 V8... but comparing a serp. setup from a friends '87 350 and my '79 350 there are a couple extra accessory holes in the newer heads that were not in the older heads. The holes in my '79 were still there on the '87 plus a couple extra's. I think the whole purpose of the 4.3 was to use the same parts and accessories to save production costs so you should be able to use that setup on your 350.
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    seems like the water pumps ife seen are a mirror image of the v belt water pumps, right will i need a new radiator?
  7. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Serpentine setups on the 92 you are getting, is a reverse flow water pump, as i also mentioned, the fan will also spin in the reverse direction from the older engines, i have a serpentine on my '89 and i also have a '94 Chevy truck with the 4.3 in it with the same setup.
    Unless you just want to go with the serpentine kit you can get from like jegs or Summit, they just use new pulleys and all factory components, everything will still spin in the same direction.
  8. 4xcrazy
    Oct 31, 2003
    9,471
    5
    No you will not need a new radiator, those are the same. well they flow the same anyway.
