dumb question
Discussion in 'The Garage' started by S. Burnham, Nov 30, 2005.
  1. S. Burnham
    S. Burnham Registered Member
    Dec 12, 2004
    64
    hattiesburg, ms
    what is a zero rate spring and how do they work?
  2. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    a zero rate is an inch tall block that bolts on to the spring pack to either be used as an extra inch for clearance or to move the axle foward or backward.
  3. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    its basically just a block about 3/4" to 1" thick that has offset centerpin hole most can be used centered or the offest to onside is 1" and the other is 1.5"
    o and they go between the spring and the perch
  4. S. Burnham
    Dec 12, 2004
    64
    hattiesburg, ms
    is this for tire clearance in the fenders or is for the little xtra wheel base?
  5. wubba_65
    wubba_65 Registered Member
    Jun 22, 2005
    41
    Alberta, Canada
    clearance for sure, wheelbase if you offset.
  6. S. Burnham
    Dec 12, 2004
    64
    hattiesburg, ms
    how much xtra wheel base, and does this effect steering linkages?
  7. lrazer
    Oct 3, 2004
    231
    Mokena, IL
    1" or 1.5" usually
    however much the zero rate is made for
