Dumb Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Fast, Dec 24, 2000.
  1. Fast
    Fast Registered Member
    May 4, 2000
    29
    Louisiana
    Well actually 2 On an 84 which way do you turn the front hubs to lock them? An I have been getting the dreaded hot gear grease smell after even a few miles of driving in the front end area of the truck. any help, as I am taking it to Missouri early Tuesday morning and would like to catch what it is before I go.
    Fast 84 K5
    http://www.fast.coloradok5.com
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I've got Warn premium hubs on my Blazer and mine turn clockwise to engage. I can't imagine why yours would be any different, but who knows.
    '73 K5
    Chevy good...Ford bad
  3. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I'm gonna gues you have already checked the fluid level in your diferential.....and checked for the obvious oil leaks...seems to me...if you can smell the hubs area, it's too late and you're hearing other noises also...bad bearings usually don't smell, they grind (roar)....Chevy's are really bad about leaking from the rear of the valve covers down the back of the motor...pretty hard to spot sometimes...if you have manual hubs, and your transfer case is in 2wd....the front diff isn't even turnin'.....I'd be more inclined to look for the oil leak....good luck...JD
    89 Jimmy headers built 700R Auburns Molys 4:10 4" 10B/12B Con-ferrs 10" Rallies 33" BFG Muds Alpine/Fosgate
  4. Grim-Reaper
    7,385
    Atlanta
    I believe 84 came with auto granading locking hubs. If you have locking hubs then they are aftermarket. The brand should be on the face. get back with us when you can tell us a brand.
    Look at your exhaust manifolds and around the valave covers. only place that gets hot enough to burn off oil is the manifolds and exhaust. probably a valve cover leak. Cheap to fix if you can do it yourself. Get it hot and look for the smoke.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  5. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    first off, no question is dumb if you don't know the answer to it, that is why this forum is here.
    Second, every hub that I have ever been around has turned clockwise to lock and counterclockwise to unlock.
    Check your diff fluid to see if it is full and reach in to get some on your finger, feel for water spots or look for discoloration.
    the only things that I can think of that would get hot at the wheel is a tight caliper which would cause some wierd smells, or the bearings. drive your rig for a few miles then get out and grab the hubs, if they are so hot you can hardly touch them then something is wrong with one of the two mentioned items.
    Dan
    <font color=red>get involved with land issues or lose the land</font color=red>
  6. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    There are no dumb questions,only dumb answers..no..thats not it. There are no dumb questions, only dumb as#es, NO,dangit! That's not right either! There are no questions,only answers..AWWWW SCREWIT! LOL j/k
    "I'm not stuck...I'm just re-evaluating my line"
  7. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Into the eggnog there ED? [​IMG] I've got some X-mas Rye on the go here![​IMG]
    Rene
  8. EDdaTREE
    Feb 18, 2000
    1,253
    Austintown, OHIO
    NAAAAH, ran out-boooo-hooooo! LOL
  9. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    I'm laughing my ass off here at work ... all by myself! Good thing I guess ...
