dumb shock question.
Discussion in 'The Garage' started by AkMudr, Jan 23, 2005.
  1. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    I think everyones allowed to ask 2 dumb questions a year, I'm usin this one form last year :D
    So.....as I search around, I see that shocks are sold by an even amount of lift inches...if you have an odd # inches of lift, would you round up or down..
    For example..you have 5" of lift..would you rock a 4" lift shock or a 6" lift shock.
    Common sense tells me to round up but I wanna see what the "viewers" think.
  2. Afireinside
    Afireinside Registered Member
    Jan 22, 2005
    61
    Aurora Colorado
    I would definitly go up to LIKE 6 inches.It will probably be just right.GOOD LUCK
  3. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    Id rather have that little bit of extra travel out of it...i have 7" and got 6" shocks (asked for 8" but i dunno if pro comp makes them that long for my truck) and they aren't too short but i wish they were longer...ohhh well, ill gain it back when i put a 14 bolt in and new shock tabs higher up on both axles...
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would use different shock mounts and the longest traveling shocks I could find.
  5. AkMudr
    Dec 30, 2004
    917
    Alaska
    I have enough on my plate and wont have the time to change the mounts for ext travels, but that is somethin i wanna do.
    kinda wierd, superlifts go from 5-8 then 10-12 inch, and im about right in the middle at 9" . i did check the specs and the only difference is 4.5 extension.
    i'll probly just get the 10-12'rs, they will get me by for a bit...cant really complain @ $15 each
    5-8
    frt - 85140 - 26.07 ext 15.5 collapsed
    rear - 85150 - see below
    10-12" lift
    frt - 85150 30.07 ext 17.5 col
    rear - 85160 34.5 ext 21.0 collapsed
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It takes about an hour to cut the stock mounts off and put a set of Ford towers on. It's a piece of cake.
  7. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    best method is to figure out what shock you want, buy the longest one they make and then use custom mounts to secure them.
    j
  8. AkMudr
    Dec 30, 2004
    917
    Alaska
    I'll do that later on. I'm just lookin to get by at the moment. With the ones I'm lookin at theres about 13.5 travel(unless i'm doin somethin wrong..34.5ext/21.0col/13.5travel), good enough for me. Its not a dedicated crawler so right now long travel shocks arent on my list of priorities.
  9. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I would get them a bit longer. I have 7" of lift with 6" shocks and I never bottom them out, but they are always pulled tight when the suspension droops.
  10. AkMudr
    Dec 30, 2004
    917
    Alaska
    At the moment its more of a price thing. I could put what they show as a rear shock ont he front, which would give me 34.5 ext and 21.0 col in front and rear.
    I dunno if that would be too much in front and maybe stick with the ones just below it at 30.5ext and 17col. The 85160's from Superlift are the biggest ones they carry.
    Like I said, I'm not lookin for somethin that'll give ext. travel, I'm just lookin to get by for the time bein. $15 each is fine for me if they'll get me by.
    I'll have about 9" front and rear and will be runnin 10-12" lift shocks, works for me.
