Dumb speedo question...
Discussion in 'The Garage' started by 78k20, Apr 6, 2004.
  1. 78k20
    78k20 Registered Member
    Feb 28, 2004
    53
    Eastern Washington
    OK, so I lost the speedo shortly after I got the truck several months back. No biggie, just figured it was that little "key" deal between the case and the adapter. I replaced upper and lower cables, the main AC cruisemaster unit, and bought all the "key's" the local dealer had. This worked good for several months, but then the speedo quit all of a sudden, entirely.
    I pulled it apart this morning, found that little "key" was sheered in half at the case, and was actually twisted almost three full rotations-making it a pain to pull out! Grrr... Anyway, I can't see anything wrong anywhere, and hooking the drill up to the lower end of the lower cable will produce about 15mph on the speedo.
    So-what would cause this little "key" to twist/snap like that? it seems to be made of a really cheesy aluminum, not the old solid steel kind they used to be-are they just not strong enough??? I did find a section of cable about 2" long that was resting on the pipe, burned a bit. Would that possibly melt the inside, making it difficult to spin the cable itself, and the drill had enough "oomph" to break it loose??? I realize most of you probably don't use the speedo anyway, but as the wife takes it to work, she gets a little paranoid if you know what I mean.
    Thanks for the thoughts,
    Best of Luck,
    Mike
  2. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    I got the one in my burban replaced because the wife got a ticket driving it. The speedo shop made me a new cable with steel ends on it. No prob since. Been over two years.
  3. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Try spinnin the cable with your fingers. Maybe just maybe you'll find it that way. I dunno though cuz on account I had all of the jacket worn off, with tranny fluid leakin out of it and the speedo still worked.
    Good luck to ya in the future.
    Allan
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    alot of the ends are plastic in the 80s, blue or black
    good luck
