dumb transfer case question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mxrcr589, Oct 14, 2003.
  1. mxrcr589
    mxrcr589 1/2 ton status
    Apr 17, 2003
    148
    poop
    this is kinda a dumb question but when is it time to rebuild ur transfer case, i have a 1990 with a 700r4 which just crapped out and i was wondering what are some signs to look for, i noticed that there is some oil leaking where it conects to the drive shaft
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Which crapped out?the trans or transfercase
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I think the trans crapped out and he's wondering if he should rebuild the t-case while he's at it.
    My thought is no. It probably doesn't need a rebuild yet. Unless you're getting funky noises, the case popping out of gear, or a sloppy chain...don't mess with it. If you're leaking fluid out of the front or rear ouput, it's just a seal that needs replacing.
  4. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Ya,I think you are right. He might be better off getting the whole thing from another truck or the bone yard.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I you are taking it out yourself you might as well crack open the case just for a look. No reason not too. My 208 seemed to be in good working order, but when I popped it open I had some bearings and stuff that were toasted.
    Pop the case and look of an excessive amount of metal on the bottom of the case near the magnet and also look for excessive chain slop. If everything is ok then it will cost you $3.99 plus tax for some RTV to seal it back up. If it is torn up it could save you alot more to get it fixed now instead of having it break somewhere in the middle of nowhere.
