Dumb valve cover breather rubber grommet question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Jan 7, 2003.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    That's a mouthful.
    I bought a neew breather for my valve covers and it came with a grommet in the package.
    The problem is that the grommet does not have a hole in it. One could use it as a plug for the hole and not put anything in there. Shouldn't there be a hole in the bottom of the rubber grommet so the breather can....breath?
    It is easy to cut a hole in the bottom of it, but then I started to wonder why it came like this.
    Does anyone know what I'm talking about?
    Here's the breather itself.
    -- Mike
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    It probably just didn't get cut out, if it's just a flap of rubber, it's not a solid piece right..... /forums/images/graemlins/thumb.gif
  3. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    On the valve covers I used to have, I bought a set of grommets for it and one of them looks like this one, no hole. I didn't know what to do with it them just like I don't know now.
    Can anyone do me a favor and pull their breather for just a minute and tell me if the grommet has a hole in it, or if it like a plug?
    -- Mike
  4. chevyfumes
    Feb 24, 2000
    38,584
    266
    Mine has the hole , I have the elite series covers and I have to remove the breather to put oil in..... /forums/images/graemlins/deal.gif
  5. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Thanks!
    -- Mike
  6. dyeager535
    26,979
    Probably totally unrelated, but my dads 454 uses a rubber plug for the oil fill hole instead of a cap. Piece of crap design, but could that be what yours is for??
    More likely they just screwed up on the plug. /forums/images/graemlins/frown.gif
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    on my new moroso vavle covers the grommet were the same as yours. the instructions said to cut the bottom portion off.
  8. 74Chev
    74Chev 1/2 ton status
    Sep 19, 2002
    102
    Oregon
    I know exactly what youre talking about. Lots of those grommets that come with breathers are like that, just cut out the bottom. I did see one dumba$$ that came into my work with his breather stuck into the grommet without the bottom cut out, and the other side had a PCV shoved into one without the bottom cut out!?!
  9. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Don't laugh too hard, that dumbass could have been me /forums/images/graemlins/ignore.gif
    I don't understand what is so hard about them cutting out the bottom, but new grommet sets come like this too.
    -- Mike
  10. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Time is money. It's cheaper to make you cut them out. /forums/images/graemlins/rolleyes.gif
  11. JakeInAZ
    JakeInAZ Registered Member
    Jan 11, 2003
    21
    Near Prescott AZ
    Had the same EXACT problem....and it's my experience that most breather caps that you buy at regular parts stores (ie. Schucks, Checker, Napa) have the same crummy gromet. You can cut the bottom off but the grommet is still not great quality and doesn't hold the breather in very well. Go to the parts store and buy yourself JUST a gromet the diameter of you breather hole. Has worked excellent for me. Just pretend the breather cap never came with a gromet and buy yourself a good, high temp, FULLY sealing one.
