dumb ?
Discussion in 'The Garage' started by oatsk5, Jun 2, 2004.
  1. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    alrighty im gonna put a 44 in my k5 it curently has 10blt can i just switch the hubs and spindle to the 44 /forums/images/graemlins/confused.gif
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Yes if you plan on keeping the same lug pattern /forums/images/graemlins/thumb.gif One minor difference you need to check though is the stub shafts. Depending on what generation spindle the Dana 44 uses. If your Dana 44 is a 71-76 small bearing it uses a different stub shaft than the '77-87(91) Dana 44/10 bolt with the big bearing. You can simply put the stub shaft from the 10 bolt onto the Dana 44 inner axle shaft if you have to change stub shafts (not nessiary if the D44 is a big bearing axle already though).
