dumb ??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Jan 20, 2002.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Well I steamed cleaned the motor and went to start it and no go (yes I did cover the dis and the carb I even double bagged them)took off the plug wires and cleaned them up and put them back on after cleaning now there is no spark and I got a pop back thru the carb with exhaust colored smoke... I think that no matter how careful I was I got water in the cap and just have to wait for it to dry but could there be anything that I could have over looked (yes I put the wires back on the way the book said) Any thoughts would be helpfull-thanks mike
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Take off the dist cap and make sure it's dry in there..... I'd check the ignition module....
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>
    Suck Fumes Ford Boy
    Stop Global Whining
    I'm in shape.... round is a shape......
  3. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    hey steph thanks for the info but I forgot to say that it was a non hei ignition and ya It is dry so looks like I push it in the garage and make the switch to hei........
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    no spark but smoke?
    wd 40 has only one real use and that is it displaces water.
    if you are having a water prob blast the inside of the cap n rotor and points area w wd40 and it should fire, or wait til it air dries
    formerly 77chev
    still a jerk though
  5. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    ya I agree with the wd-40 statement, I just pulled one of the plug wires and checked that there was spark(screwdriver and the block) and there was thankyou very much for the suggestions keep them coming again thanks-mike
  6. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    ttt-still wont,start anymore ???????????
  7. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Are you getting ANYTHING when you try to start it now? I had a similar problem after I power-washed my engine but I wouldn't get any spark. Nothing at all. I figured it was a bad ground and sure enough, I had jarred a ground wire loose from the firewall. If this sounds at all familiar, make sure your ground wires are okay.
    <font color=red>"THE HUMMER ON 'ROIDS COMING SOON!"</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/BigTex-Mean-Machine>http://coloradok5.com/gallery/BigTex-Mean-Machine</a>
  8. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    ya I pulled one of the plug wires and got spark there I tried to start it again and watched it split fuel out the carb (like a low sound pop) I am just dumbfounded check the stuff I touched so It must be something else I didn't touch......
  9. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    Just a thought, when I first got my Blazer and put a new cap on, I put the wires back on by the book and it wouldn't start. It turned out that the distributer was put in wrong. The firing order is the same, but the starting point on the cap was two clicks shifted. When I think about all the exhaust explosions, it still makes me laugh.
    I'm just a rookie though.
    Newbie, 73 Blazer project
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    for it to pop out the carb it is timing related
    recheck firing order and base timing, yeah you probably did all that already but K.I.S.S.
    formerly 77chev
    still a jerk though
  11. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Hey bob thanks for the idea It worked I just moved the plug wires one spot to the right counter clockwise and It fired right up thanks again, So now I have to circle the right firing order in the chilton'sagain thanks-mike
  12. bobsurf
    Jun 26, 2001
    410
    San Marcos, CA
    Weeee Hooo, I actually had a suggestion that worked. It feels good to give back for all the good stuff you guys have all given me.
