Dumbest Hydro Boost question ever
Discussion in 'The Garage' started by sapper, Dec 29, 2005.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Just got the system on and ready to bleed when i thought, what fluid do I use? Does the steering box still use power steering fluid and the brakes brake fluid?? Yes I feel dumb but dont want to screw anything up, thanks
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Yep they are seperated internally. Brake fluid in the MC and Power steering fluid or ATF (which ever is your pref) in the Pump.
    Ira
  3. sapper
    Jul 11, 2001
    3,052
    NoVa
  4. k5redneck
    k5redneck 1/2 ton status
    Jun 24, 2004
    1,000
    mesa AZ
    just to add to that... if atf or p/s fluid is added to the master be ready to repleace every rubber peice of the brakeing system:doah:
  5. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    My hydro boost uses DOT 5 brake fluid, not DOT 3 like vacuum boost systems.
  6. tiny2085
    tiny2085 1/2 ton status
    May 14, 2004
    160
    Two-will-uh
    I just finished my hydro assist last night, and when I got out from driving it, I heard gurgle gurgle sounds in the steering box. Do you guys think this is A)air bleeding itself out of the system B) the ATF got hot to the point of boiling ? The steering box was warm to the touch.
  7. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    if that were true then why are there rubber seals on p/s lines and inside trannies ?
  8. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    They are made of a different material. He is correct, P/S fluid in the brake system will make all rubber components bad within a VERY short time. I had a friend make this mistake once.
  9. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I'll back that up too ! The two systems use different durometer and types of material. Bad things will happen if you get the fluids in the wrong place.
    Tom
  10. rwright07
    rwright07 1/2 ton status
    Jul 30, 2005
    536
    corporate hobo
    oo man i may be in trouble.... how long does P/S fluid need to be in there before it cuases much damage?
    dont ask...haha
  11. dremu
    Feb 27, 2000
    15,952
    444
    East of San Francisco
    DOT5 is the silicone stuff, right? Ex-military vehicle, i.e. CUCV, by chance?
    My M1009 was marked for DOT5, but the previous owner, a local PD, had already converted it BACK to DOT3.
    Which is good, as DOT5 is hard as hell to find 'round here. And expensive. Should I ever get another CUCV, I'm flushing the thing out with DOT3 and keeping it there.
    -- A
