Dump trailer Info
Discussion in 'Tow & Trailer' started by perp, Jul 2, 2006.
  1. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    I am about to start building a new dump trailer and I have been looking at others designs for detail info. I have seen both the straight ram and the scissor lift styles, but no manufacturer can give me a consistent answer as to which is better. I am guessing that the Scissor (single or dual ram) is stronger as i see it more often on larger trailers (over 7K gvw), but I have seen some 21k's with straight rams as well as the 10 wheel kenworth dump i used to operate had a straight ram.
    Any opinions, is it just cost related or maybe manufacurer preference or is it based in duability?
    BTW i am making a 10K-16K range dump (not finalized on the size yet). more than likely a 9,999 to keep under class A and to avoid the $850.00 :eek1: perm plate.
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    W/o knowing a lot about the sissor style I'll guess that those can use a ram that is either a shorter stroke or a smaller bore. Either would cost less. The down side is that the linkage weight eats into your net capacity and has more to maintain.
  3. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    from what i have seen the bore is a lot bigger in a scissor, but it definetly is a shorter stroke. From the best i can tell so far the scissor doesnot have to displace any of the cargo area as it folds flat under it. a large single ram (think dumptruck) has a large area in the front of the bed boxed to hold the top of the ram, reducing cargo volunme. maybe it makes for too muck toung weight too?
  4. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    I'd buy a used one and fix it up.
  5. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    I like to build things (like many others on here) and have a few successful trailers under my belt. I want to learn more about hydraulics and this is a better way than plan "b" (plan "b" is to fab my own hydro steer). If I make a few mistakes along the way i shouldn't die, so long as I keep my head out from under the box during lifting:wink1: . if all goes well I am on to steering parts. here is a picture of the last trailer I welded up (non dump). it about 2 years old in this pic and this is after i sold it to a friend. kinda crappy pic but the only one i got.
  6. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    OK. Learn on. :waytogo:
  7. sweetk30
    Nov 1, 2004
    25,550
    543
    horseheads , ny 14845
    i have a single ram style dump out front. i can take pics for ya if needed.
  8. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    I got's a dumper at the shop now that I think of it. I'll grab pics next time I'm out there.
  9. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    any and all pics are greatly appreciated.
    Thanks Guys
  10. sweetk30
    Nov 1, 2004
    25,550
    543
    i have had 2 yards in this of pee gravil, she dumped it no problem. pulled great. has 225/75/15 tires and brakes on both axles. back door is setup so you can wiggle it up off the hinges. and the pass side lock is just a old spring eye bolt and bushing tube cut in half and spaced out for bolt to piviot.
  11. sweetk30
    Nov 1, 2004
    25,550
    543
    few more.
  12. sweetk30
    Nov 1, 2004
    25,550
    543
    forgot some. her ya go.
  13. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    Thanks man, lots of cool pics that should help alot. I do like the straight ram myself.
  14. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    How much would that 12v motor to power that ram cost? My car trailer has a dumping deck, but the ram is just plummed back into its self and acts like a big shock absorber so the thing doesn't slam up or down. Sorry for the minor hijack.
  15. sweetk30
    Nov 1, 2004
    25,550
    543
    new i have seen around 5hundred bucks. but used from like a lift gate or some other app. i have seen 1-2 hundred bucks. watch the psi specs tho on some. small stuff for certian apps.
