Duplicolor or Herculiner truck bed coating
Discussion in 'The Garage' started by MTBLAZER89, Apr 1, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Has anybody used the Duplicolor truck bed coating. It is 39.95 for a gallon at Wally-World. I was just wondering how it will hold up compared to Herculiner. Thanks. BTW will a gallon do just the rear of a K5?
  2. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    get herc, they have a $25 off mail-in deal going right now... find it on sale some place and you'll be set.
    j
  3. JSH
    JSH Registered Member
    Oct 20, 2002
    75
    Iowa
    I don't have first hand experience with Herculiner but was very disappointed in the Duplicolor. It is basically just thick paint.
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Make your own:
    Buy some black (or whatever color you want) exterior paint, put into large pail, add 1/4 ammounts of flour per gallon. Stir and paint on /forums/images/graemlins/waytogo.gif
  5. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    man i dont know about that flour in the paint thing, I was thinking more along the lines of silica granuls /forums/images/graemlins/waytogo.gif
  6. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    how about ground up plastic.... it would have abrasion resistance...
    that being said... alot of research went into the bed coatings... using a proven one is prudent... making your own sand box mixture might be inexpensive... but it might just be really micky rat as well
    /forums/images/graemlins/peace.gif
    cam
  7. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    It isn't worth the can it's contained in.
    The Plasti-Kote stuff is 10x better than Dupli-Color and it still sucks compared to Herculiner.
    As far as coverage, I wouldn't know. I've only used Plasti-Kote and Dupli-Color rattle cans.
  8. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    Duplicolor SUCKS!!!! I put it on my S10 bed...it was like hard plastic. It would even rub off onto your hand. My toolbox would slide across it easier than the stock paint job under it! /forums/images/graemlins/angryfire.gif
    ~Jason
  9. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I have Herculiner in the bed of my truck. I am not impressed with the duribility at all. In three months the back of the bed rail where the front tire of my motorcycle rubs up against it was bare metal. It also fades quite a bit. Looks great when it is just done though. Next time, I am going to just bite the bullet and have Line-X or Rinoliner sprayed in and be done with it. Good luck.
  10. Bruiser
    Bruiser 1/2 ton status
    May 21, 2000
    320
    Caldwell,Idaho
    I will second (or 3rd and 4th) that Dupli-color Sucks. My boss had me paint is flatbed trailer with it and it will scratch right off the brand new fenders even after ruffing them up with a wire brush and cleaning them with a tack cloth. Told him he should of POR-15 the dang thing , hehe
  11. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    I have duplicolor and it hasnt been that bad
  12. 78k20
    78k20 Registered Member
    Feb 28, 2004
    53
    Eastern Washington
    I'd say the Line-X is about the best there is-I know a lot of people who've gone with Rhino and have been very disappointed with large sections bubbling off, then having difficulty with warranty repairs on them. Only know of one guy with a Line-X repair, that was fixed no questions asked, and not a problem since-turned out he had some rust issues under the paint in that location too, so it really wasn't the liners problem.
    As for Herculiner, I did my entire trailer in it, which I pull mostly up gravel roads and such. I did two coats on the thing-concerned about the gravel chipping it off, and couldn't be happier with it's performance. I don't know how many thousand miles are on it now, and I've replaced the tires on the trailer-the Herculiner is still in great shape. Only spot missing is where I had to grind it off to weld the tailgate tab back on.
    I think with any of the above suggestions for bedliners, the actual preparation of the area to be coated is what is most important. Follow the directions exactly as they state for initial prep work, I think you'll find the final job will come out a lot better, and last a lot longer.
    Best of Luck,
    Mike
  13. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have herculiner in my s10 and dont like the durability. it peels up easy and pulls the paint with it and sometimes the primer also. that is with the roller cover that comes in the kit.
    one of my friends used it and used a regular paint roller cover and it turned out nice and lasted quite a while.
  14. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    I am pretty sure I am going to go with Herculiner. I may use the Duplicolor on the rockers or inner fenders or areas that will need to be touched up once in awhile. /forums/images/graemlins/waytogo.gif
  15. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    I used Dupli-Color to line the tub in my Jimmy. I ended up needing 2 gallons and it is horrible. The stock 30 yr old paint held up much better than this crap. It literally chips off with your fingernail. Dont use Dupli-Color!
  16. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Don't use Dupli-Color. Plasti-Kote costs the same as Dupli-Color ($6.99) at Wal-mart. Dupli-Color is worse than using regular paint. I did the same preparation for both Plasti-Kote and Dupli-Color and the Dupli-Color has neither held up nor stuck to anything. The Plasti-Kote has fall off in some spots but that's because of pre-existing rust (inner wheelwells).
  17. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    Duplicolor user here. Yeah, it sucks. /forums/images/graemlins/angryfire.gif I spent a lot of time prepping the tub with professional grade de-waxer / cleaner and sand paper but still the stuff will come off with a fingernail. But it is easy to patch with a spray can of the stuff. Still couldn't justify the $$$ for a Rhino though.
  18. BIGBAMA74K5
    BIGBAMA74K5 Newbie
    Mar 8, 2003
    4
    Hoover, Alabama
    I used Duplicolor on the interior and exterior of my 74 K5 three years ago and I have never had a problem with it. The only time that it ever scraped off is when I was backing the K5 out of my garage and did not pay attention to the sides (garage was too small anyway). Other than that I have never had a problem. I think that a lot has to do with the prep work. Just my experience.
    Rush
  19. vegas76k5
    vegas76k5 Registered Member
    Apr 20, 2003
    31
    Las Vegas, NV
    Rush, how did you apply the Duplicolor? I have 4 gallons of Duplicolor and all the stuff to prep the truck collecting dust. I was planning on using a compressor to spray it on. Only reason I haven't done it is the amount of time to prep it propperly. After seeing this topic, I don't know if I want to waste my time.
  20. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    When I built my new bed I applied Duplicolor bedliner to the inside. I had brand new bare metal, prepped it per the directions and applied the duplicolor with a spray gun. It looked really good for the first day. Day 2 it started fading and it's all different colors now, even some white spots... After about a month, rust is coming through the duplicolor from the metal below. Now I have parts flaking off and you touch it wrong and it comes off. I'll never use the stuff again, I'm going to try and pressure wash most of it off then sand blast the rest and do it over in herculiner, used that in the past and loved it.
