Duration or Lift......and any experience with the crane "fast bleed" lifter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by twenty_below0, Feb 24, 2002.
  1. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    Duration or Lift......and any experience with the crane \"fast bleed\" lifter
    Ordering my cam for the new beast tomorrow and I once heard a saying on here that duration equals torque and lift equals h.p. ...........or vise versa so which is it and also how about some opinions on the fast bleed lifters by Crane? I've used the RHOADS lifters before and they worked good but I really didn't like the noise they make at an idle so I'm wondering how much quieter these new fast bleeds are?? As usual allinfo appreciated
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Re: Duration or Lift......and any experience with the crane \"fast bleed\" lifter
    What year blazer are you going to install the cam into? Duration does make torque and lift will help HP. If this is going into a later computer controlled blazer you need to watch out for how much duration and lobe separation you choose. If the specs are too much the computer will get all confused and you won't be happy with the results. As far as your lifters are concerned, I would stick with factory lifters and no anti pump up style, they are very noisy.
    1989 blazer, 383 stroker, D44 / 14FF, 4.56, locked, 35 BFG mud
    Scott
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I used the Crane fast bleed lifters in my last 68 Camaro build on a 327ci. They were not "noisy" but just stlightly louder than stock. They definately smoothed out the idle and lent to a better vacuum.
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://community.webshots.com/user/borregok5> Pictures</a>
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Generally:
    More Duration = High RPM HP
    More lift with less duration = Low RPM Torque
    Other factors play into it too though. Don't just pick a cam based on those two factors. If you have fuel injection and a MAP sensor, your cam better have a wide LSA.
    Tim
  5. twenty_below0
    May 16, 2001
    436
    The reason I ask is that comp makes a cam that's 218 degrees of duration at .050" (intake and exhaust) and 488 lift which in comparison with the extreme 4x4 cams is better......what do you think, and also has any body considered having a custom ground cam??
