duty cycle?
Discussion in 'The Garage' started by tecton, Feb 19, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    Duty cycle: 12% @ 80 amps, 20% @ 60 amps
    whats that mean
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    I believe it means the unit is designed to work continuously 12% of the time @ 80 amps and continuously 20% of the time @ 60 amps.
  3. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    It relates to the amount of time within a ten minute cycle that one can operate the electrical appliance without risk of overloading or overheating. So 12% would be 1.2 minutes out of every ten, and 20% would be 2.0 minutes, and so on. If it is a welding machine, some of them have overload capacitors built in to shut off the current if the transformer overheats.
  4. tecton
    Dec 1, 2002
    1,553
    WV
    thats continuously welding?
    so if im just spot welding ill probably never exceed that
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    spot welding will not over load the machine.you should be fine.
  6. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    machines with better duty cycles are of better Quality /forums/images/graemlins/thumb.gif
