DV Camcorder to DVD help
Discussion in 'The Lounge' started by Beast388, Sep 1, 2004.
  1. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I need to tap the vast knowledge of CK5 for some help with AV stuff.
    I need to transfer a video file that is on an analog tape in a DV camcorder onto my PC and then make a video CD or DVD.
    After doing a bit of research, it appears that I need a PCI video capture card and a cable to connect the camcorder to my PC. The only ports on the camcorder are USB, DV and AV.
    My PC is a 3.2 P4 with a Gig of RAM, 128mb vid card, DVD-rom and DVD-RW so the only hardware that I think I need would be the capture card.
    Can anyone tell me what I need and need to do to make this happen? Thanks in advance for the help!! /forums/images/graemlins/waytogo.gif
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    in response to beast388
    its bad when you can talk in code
    713883502054414.... lol yeah? well
    735144002032056014513
    so /forums/images/graemlins/tongue.gif
    buy a firewire card and studio 9
  3. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Yep, sounds like that is all you'll need. Of course you'll need software too. Make sure that the stuff you get will handle analog video if that is indeed the medium the vid is on.. Not everything does. A lot of it is designed for DV only.
  4. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Do you have a firewire card? I'm not sure if you can use it with analog tape in the camcorder, but the DV connector should plug into a firewire and be a world faster to transfer than video capture card. Even for future projects beyond this one, the dv-firewire should make a big difference. On my dv camcorder, you can only transfer stills over the usb cable to the pc, transferring video is not even an option without DV/firewire. However, using my mac with the DV cable absolutely ROCKS. I can control the camera through the cable, and the video transfer is perfect. I started downloading the video to my mac, then picking up the completed videos on the pc to burn to dvd. Of course, our friggin dvd players won't play any dvd+r discs...
    I have a PC video capture card, and the quality to file size leaves a lot to be desired. I had planned on taking all our home videos and transferring them to dvd with the capture card, but the quality was horrendous, and with 2gb+ file sizes, it was a huge pain in the butt to try to edit. I'd even offer to send you my old capture card if I hadn't re-assigned it to the security computer...
    So basically, I'd see if your camera can transfer the analog video over the DV line, and if so, buy a firewire card instead of a video capture card, and make the transfer that way. Hopefully, the camera came with video software...
    Normally I wouldn't say this, either, but a Mac would probably help you out quite a bit with this...
    Oh, not that you asked, but here's a quick sample of a completed video from our dv camera to mac to PC (camera was brand new and much lighter than expecting, that's why the video is all over the place)...
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you dont need a video capture card you need a firewire card and cable. what brand of camera is it? on my sony camcorder i have both usb and firewire but the usb compreses the video and the firewire dont. now you said you want to burn it to cd or dvd right? what are you going to do with it? is it just to use on a pc? or are you wanting to play it on a set top dvd player? if its just for pc then if it will fit ya you can put it on a cd. if you want to put it in a set top dvd player you can make a vcd or svcd on a cd and some players will play it.
  6. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Thanks everyone for the replies so far.....
    My PC has 4 firewire ports but I assume that the firewire card you speak of is different. Once I check TigerDirect I may answer my own question.
    The camcorder (my boss'...this is a work project) is a Canon NTSC ZR85 Digital Video Camcorder. I assume the video is analog because it is recorded on tape.
    Newyorkin....you are correct, I can only download the still pics off of the SD card using the USB cable.
    Does anyone recommend a certain brand of firewire card? This is the first of potentially many projects like this.
    Does anyone know which port I need to hook this firewire cable to? Like I said above, the ports are marked USB, AV and DV. /forums/images/graemlins/thinking.gif
    Thanks for the help! /forums/images/graemlins/waytogo.gif
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if your pc has 4 fire wire ports then you only need the cable /forums/images/graemlins/thumb.gif
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    oh and the fire wire cable hooks to the dv port on the cam
  9. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I may have answered some of my own questions...... /forums/images/graemlins/histerical.gif
    The DV port on the front of this camera is a 4 pin and the firware ports on my PC are 6 pin. It appears that this cable will do the trick.
    Now, can anyone tell me since I have 4 6 pin firwire ports, do I need a firewire card? I would guess no, but you guys are the experts. /forums/images/graemlins/deal.gif /forums/images/graemlins/waytogo.gif
    My computer came with Ulead VideoStudio and Windows movie maker for software. Will either of those two work? /forums/images/graemlins/dunno.gif
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  10. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes that is the cable you need. no you dont need to buy a fire wire card. i use and like the ulead 7.0 works really well and is easy to use /forums/images/graemlins/thumb.gif
  11. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    LOL!
    Shannon, you answered my questions in the time it took me to type that last post! /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    Thanks again! /forums/images/graemlins/waytogo.gif
  12. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    no problem always glad to help when i can /forums/images/graemlins/thumb.gif
  13. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Oh hey, the tape should be digital if it was recorded by that camera. It should be digits recorded to the tape instead of waves or whatever the old analogue was...
  14. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Ah Ha......thanks Ratch, that makes sense! /forums/images/graemlins/waytogo.gif
