DW, d60, & fender washers
Discussion in 'The Garage' started by fatbob, Nov 12, 2006.
  1. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    I've put two fender washers under the top cap on the d60, and it greatly reduced the tendency of death wobbly.
    But it's not clear if I need to put washers under the BOTTOM CAP also, or can I go ahead and add some more under the top cap?
    Most threads I've read just mention putting washers under the cap, and thats about it.
    Bob
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    its only under the top caps...do yourself a favor, buy new springs and bushing and dont shim, then go from there
  3. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    yeah, address the REAL problem. If castors off, shim it. If TREs are worn out, buy new ones...I fully rebuilt my 60 (aside from getting gears in it) and it doesn't wobble ONE BIT now. new steering parts, new kingpin parts, new bearings...the works. It drives GREAT now.
    I had DW on my 10b...i know part of it was caused when i got slack in my hub bearings...and im gonna guess some of it was from the tie rod and/or drag link...im sure they BJs have also seen better days too.
    Edit: btw, make sure that the front end is aligned too...more than just castor...toe in/out can affect it too.
  4. fatbob
    Jul 3, 2003
    420
    Phoenix, Az
    I know thats good advice guys, But sometimes ya gotta stretch those dollars.:rolleyes:
    But for now, I think I'll add another washer to the top caps.:doah:
    Bob
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Do the washers. When you get some $$ do the springs and bushings.
    I rebuilt my D60 from the ground up and had no DW until I went to crossover. Then I needed two shims and a steering stabiliser to *mask* it. I can still feel it trying to start now and then, and on rough roads I will still get it on occasion
  6. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    You don't have to stretch them TOO far, brother. ORD sells the bushing/spring kit for around $20 for BOTH sides. Replace the springs and bushings, and then go from there.
  7. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Another one going to say the bushings and springs are cheap. I bought mine from a local HD truck center. Only prob here is I still had DW:mad: I think I have narrowed it down to my shot out shackles and bushings, everything else in the suspension is new.
  8. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I replaced my kingpins 2 weekends ago, wheeled it this weekend, and the front end is much tighter. I am no longer running fender washers.
    Its worth the time and $ to be safe.
  9. destinbeachman
    destinbeachman 1/2 ton status
    Aug 31, 2005
    365
    Florida
    Don't have it as far as I know
    Now I'm starting to worry about DW and I don't even have it!I finally got around to rebuilding the one that's been sitting in my garage and am hoping to have it under the '70 by the end of the week.And you guys are freaking me out!My rig is pretty much my daily driver.I try to take my bike as much as possible but if it's raining or I need it at work on the beach I have to drive the Blazer.I mean I GET to drive the Blazer.It has great on-road manners and I have driven it as far as Memphis.Lotta power,soft-top,lifted,of course I drive it!But this DW thing has me worried that I'll be totally changing all that.I used all the new parts and have a new steering box and new ORD highsteer so all the rod ends will be new.And I'll use the old tie rod to setup the initial toe-in.And it won't be rotated so the caster should be stock.What else?
