Dynatrac Inspired 14BFF?
Discussion in 'The Garage' started by PsychoticDeadGuy, Mar 15, 2006.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    I will be pulling my 14bff in a couple weeks or less and I wanted to build my own Dyna D60 but I dont feel like spending the money on a rear D60. So I am gonna build a Dyna 14bff.
    So, if I cut the whole bottom section off of it and rebuild it with 3/8" plate and MIG welded with a TIG weld over it would it work good? (TIG to make it look purdy)
    Are the Yukon or similar 5.13 ring gears the same as the 3.73 in outside diameter?
    How much can I shave the ring gear without sacrificing the strength?
    I know these are more of the extreme questions but I wanted to find out what the CK5 guys had to say. I have been spending more and more time at pirate because I am getting more into the exteme side of the sport. Still gotta represent CK5 and the full size Chevy though. Thanks.
  2. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    really dumb question I'm sure... but why? ff14b is about as good as it gets. If you want another inch of clearance, just buy tires 2" taller. :grin:
    j
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    the housing is cast iron. do you have the ability to weld to cast iron? not easy and you have to carbon arc weld it. you cant mig it. between prehating the metal and whatnot, its not easy.
  4. PsychoticDeadGuy
    Jan 8, 2005
    753
    OK, I wont MIG it then, I can TIG or Stick weld it. If I stick weld it, what rod do I use?
  5. 79k20350
    Nov 22, 2004
    7,757
    Ct
    you should really do some research on it becuase its pretty indepth. ive never done it but tlaking to my dad (he used to be a millwright, was a welding specialist) its very hard even for expierienced guys to get proper penetration, preheat it enough, no cracks etc...
  6. PsychoticDeadGuy
    Jan 8, 2005
    753
    Alright, I understand that. I work in a welding shop. I mostly do TIG. But there are many certified Stick welders in there that could do it for me. I dont go back until monday and was just wondering if there was anyone here that knew what i needed to do.
  7. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    THERE was a write up somewhere about a guy migging it up and plating it all in .....id do a serch for it here and on pirate . I dotn remember where i saw it but it was a good article .
  8. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
  9. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    The housing is NOT cast iron, its cast steel. You can weld to it no problem.
  10. 79k20350
    Nov 22, 2004
    7,757
    Ct
    ooppppps!:doh: what i said still applies though...only to cast iron and not 14 bolts...
  11. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    It is still good to pre-heat just for penatraction purposes. Just get it nice and hot and start welding. You will be amazed at how well it penatrates with the pre-heating.
  12. PsychoticDeadGuy
    Jan 8, 2005
    753
    I preheat everything that I weld when I am doing stick. It does help a lot. That link was awesome. That axle has 1" more clearance than my 10 bolt with 39.5" Boggers. I am definatly going to do it. Dont worry, the 10 bolt I have in front will be gone soon enough. No flaming.
  13. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    here is mine. i have abour 1/8" clearance at the ring gear. i sticked it but i would not worry about MIGing it. i am installing a BTF truss but the main reason it for an point to attch a traction bar.
  14. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    did you turn down your ring gear ?
  15. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Yea but read the end of that thread carefully..... that guy is still chasing leaks and his housing is now flexing enough that the ring gear hits the lower plated area at times....
    The ground clearance is sexy, but losing all the strength and integrity of the housing isn't.... :thinking: I'll betcha that eventually that axle folds in half starting right where that new lower plate is.... :deal:
    This is one of those times where the cure might be worse than the disease.
  16. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    personally, i dont like the idea of cutting out part of the pig, and attempting to weld it back together. just get out your grinder, and smooth everything out, install a good quality thick cover (probably good to have it on hand before you start grinding), and dont worry about the clearance. if you smooth it good enough, you should be able to drag it over just about anything, and not worry about ripping you lower plate off.
  17. 79k20350
    Nov 22, 2004
    7,757
    Ct
    thats exactly what i believe. what did he gain an inch at most? if you really care that much about ground clearance get a eaton, you can shave it to have more ground clearance than a dana 44. as long as your 14 bolt is smooth underneath you shouldnt have a problem with rocks.
  18. beater74
    May 29, 2001
    1,749
    atlanta
    yeh that is another reason i am trussing my pig. i trimmed just enough to stay out of the ring gear, a trim like i did is plenty enough. i'll post some picks when i get it put back together in a few weeks
  19. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    I'd get an eaton before I'd go modifying a 14bff housing. I drag my 14 bolt over the rocks with 36" tires and I don't drag my eaton with 35's. You can use the guts of the 14bolt in an eaton too. There is of course, idiosyncrosies about the two, but if I was to do the K5 rear axle again, I would have looked for an Eaton, mainly because 4" lift and 36" tires is as far as I want to raise the COG.
  20. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    I agree,I saw the write up on pirate and thought it sounded like something I would like to do to a 14bolt Im going to use.I printed all the info out and started to lay it out and fiqured by the time you add your plate back in there you have not gained that much at all.Plus you would be cutting into the webbing on your pinion bearing if you removed as much as they did!
    Also read the link from here about the guy who cut his and is having some issues like the ring gear rubbing the cover when he puts the brakes on,just imagine crawling with a wheel off the ground would probably crack the welds on the outer edges.
    I think a good truss would be a must,sounds like beater74 should have no problem with his.
