Dyno numbers base crate 350
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by turbo, May 5, 2000.
  1. turbo
    turbo 1/2 ton status
    Feb 18, 2000
    109
    This is from Chevy high performance mag Sept 1999
    They tested the base new crate 350 from GM
    They got it from Scoggin Dickey in Lubbock
    Web site www.scoggindickey.com
    Advertised as 8.1 to 1 but measure to be 8.4 to 1 compression.
    Stock cam waranty not affected by external add ons.
    Round 1
    Stcok Q jet manifold and stock Q jet carb
    Stock cast iron exhaust manifolds to 2.5" duals with turbo style mufflers
    Tatal advance set to 34 degrees and 92 octane pump gas.
    peak TQ 324 at 3700
    Peak HP 239 at 4100
    Round 2
    Same as above but add hooker header with 1 and 5/8 primary tubes
    No rejetting of stock carb or timing change.
    Peak TQ 349 at 3600 RPM
    Peak HP 255 at 4400 RPM
    Round 3
    add an Edelbrock preformer Intake Manifold
    All else same as 2 above
    No jet or timing change
    Peak TQ 350 at 3600 RPM
    Peak HP 265 at 4300 RPM
    Gives some real world numbers for that basic crate motor.
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Thanks for the info turbo. I pretty much got the Round 3, but take out the hooker headers and add in Flowtech Afterburners. Anyways, now I know where my GM crate stands.
    Thanks.
    Boss
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Real world hum,
    are you saying that when 4 wheeling in your blazer you motor is turning 3600 rpms ?
  4. 88Jimmy
    88Jimmy 1/2 ton status
    100
    Las vegas, NV
    In low range you could be!!
    350 Vortec TPI D60 14Bolt 4.56 4"lift 35 BFG A/T
  5. turbo
    Feb 18, 2000
    109
    Well the mag has complete numbers TK and HP vs RPM.
    You pick what you want.
    Here in the real world engine HP is done at peak and honest guys quote what RPM produced the peak.
    Perhaps you pefer chevy parts guy rectal pluck but for me real world means an off the shelf no speical prep engine hooked to a dyno not just a wag.
    But for you wag guys sorry I bothered.
  6. Executioner
    Feb 22, 2000
    1,530
    Hold up, I think your missing the point !
    Thanks for posting the #'s
    To me real world 4X4 have to have bottom end toque.
    If you only post at one rpm, and the peak, whats that tell us about the bottom end ?
  7. turbo
    Feb 18, 2000
    109
    Pick an RPM or 2 and tonight I'll post the numbers for those cases at your desired RPM.
    Of course case one will likly be marginally highest at low RPMs.
    But when some one asks what HP is the base crate engine rated at that is commonly taken as peak HP not low RPM HP.
  8. Executioner
    Feb 22, 2000
    1,530
    Ok, I see you point about the crete engine HP, but I sure hope
    your not spinng them at 3600rpms off-road. or on the freeway,
    because they will not last very long at that rate.
    If on the other hand you 4X4 in the 1500-2500 rpm range most of the time
    and have more low end torque in motor A then motor B
    this is real world to me.
    And if your in a mud hole spinning at say 4500 rpms, and going nowhere(traction limited)
    what good does 300 HP vs 350 HP do for you ?
