DYNOMAX EXHAUST INSTALL!!! SUCKED!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rick88blaze, Oct 13, 2003.
  1. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I installed the dual exhaust kit and headers from dynomax today. All I've got to say is, "IT WAS A PAIN IN THE ASS!!" My K5 must be half '88 and half '89. the pipes that run under between the headers and mufflers did not line up at all. i made them work, but there are a couple places the pipes hit the frame or crossmember. the pipes that run over my rear axle were fine, though.
    the headers weren't that bad to install. on the passenger side i had to remove the lower bumpstop that would hit the differential. other than that, they weren't bad at all.
    i still think it was worth the effort, though. it sounds pretty good. i haven't had a chance to test drive it yet, but i noticed that when i would rev it up in park, that the engine was making the body, and chasis move more than before. /forums/images/graemlins/deal.gif/forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    rick
    P.S. anybody interested in a factory Y-pipe, AIR exhaust manifolds, and a catalytic converter, and glass pack. $100 for everything. plus shipping of course. /forums/images/graemlins/thumb.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have installed 3 kits no issues.
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Out of curiosity, what type of Dynomax mufflers did you use (Turbo II, Ultra flow, etc...).
  4. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i used cherry bomb turbos. they have the exact dimensions as the dynomax ones the kit recommends using.
    I think my K5 is in it's own dimension anyway. i had to get a new driveshaft done up just for a 2 1/2" lift kit. and i had to lower my t-case for the lift. everything i've done on mine has been twice as hard as i think is should have been. it's like my truck was a test vehicle for new parts.
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I know that feeling....
  6. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    /forums/images/graemlins/rotfl.gif I thought it was just me......
  7. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    SUBFAN & fad2blk99;
    I'm glad you two posted those remarks, b/c I was feeling kind of lonely, thinking that I had the only truck they put test parts on!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Well I wish it was hard to work on my truck. My truck is easy to work on. Too bad that once you fix the small things that were going wrong, something really big and bad happens. Like I finally got it running, the clutch releases correctly, turn signals work, etc. and the front axle joint replaced and took it out and rolled it the first weekend. /forums/images/graemlins/smile.gif
    Oh well...who needs a nice looking body on the truck. It's highly overrated. Right along there with balanced tires.
  9. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Rick,
    Let me know after you do your test run if you notice a lot more power or not, I am really considering putting headers on my Jimmy. I also heard they create a lot of heat and cause your engine to run a bit hotter. Would you post an update? /forums/images/graemlins/grin.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They don't create any heat, your engine is where the heat comes from and it won't make any more from having headers on it.
    Headers can increase your underhood temperature, but I doubt you'd ever notice.
    An engine that breathes better most likely will cool better, but I can't say that's a total fact. I have never had a heat problem with my headers, although they're coated.
  11. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Jeff,
    i haven't really had a chance to open it up yet, but around the base here, i've noticed that i don't have a hesitation off of the line anymore. my engine runs the same temperature, it's just a bit louder when i romp on it now. I LIKE IT!!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
    Rick
  12. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Sweet! /forums/images/graemlins/thumb.gif
  13. bpiccioni
    bpiccioni 1/2 ton status
    Aug 11, 2002
    187
    Eugene, OR
    So what was your total cost? I need to look at installing new exhaust myself (I'd love to go dual and get rid of that LOW Y Pipe).
  14. 1989k5
    1989k5 Registered Member
    Jun 10, 2003
    36
    near Lake Superior, Wisconsin
    I guess I would be interested in the price too. I have thought of buying a pipe bender ($200 bucks) and make them, but if the cost was around $300, not including the headers, I would be interested.
    [/ QUOTE ] Ranger: When you care enough to send the very best.
  15. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    it's $115 for the dual exhaust
    $160 for AIR headers
    $110 for reg. headers
    $60 for 2 cherry bomb turbos from autozone
    about $10 in extra clamps and stuff
    rick
  16. bpiccioni
    Aug 11, 2002
    187
    Eugene, OR
    So where did you find those prices on exhaust kit and headers?
  17. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    www.jegs.com that's where i orderd the exhaust and headers from.
  18. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
  19. bpiccioni
    Aug 11, 2002
    187
    Eugene, OR
    I just got my Jegs catalog in the mail today - gonna have to get em to send me another one cause this one is shot - missing the cover and is coming apart. Maybe the USPS workers had to use it or something /forums/images/graemlins/laugh.gif
    I got my eye on the coated headers for $229.00, lifetime warranty, but I wanna make sure they work w/ AIR and have an O2 hole. From looking at the catalog, it appears that I will have to call someone at JEGS and see if they can find out.
    Dnyomax Cerama Coated Headers
    I downloaded the Dynomax PDF, and it looks like they dont have the Ceramic Coated headers w/ AIR for any 4WD GM Truck up to 91, so I might have to settle for the Black painted ones. Anyone know different? I'll still call JEGS and see if they have the coated Dynomax w/ AIR that will work on my /forums/images/graemlins/burb.gif
    Dadgummit! It sure seems like $80 more than the black painted headers is a deal for a lifetime warranty and better heat characteristics. From what I've read, it would cost me almost that to wrap the headers.
  20. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    I've been running those headers for about 3 yrs no without any rust problems. They don't have the air hook ups or the o2. I was able to go without the air because we don't have inspections here, but had to get a bung welded on for o2. Jeg's has that part to.
