dynomax headers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by the_goat, Oct 7, 2004.
  1. the_goat
    the_goat 1/2 ton status
    Sep 13, 2003
    113
    Phoenix, AZ
    has anyone used the dynomax long tube headers on their k5? If so, did you like them?
    Thanks john
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have a coated set on my K10. Perfect except for shackle bolt interference. /forums/images/graemlins/thumb.gif
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I have a non-coated set on my K20. I had the same shackle bolt to collector problem that Tim did, but I had the exhaust shop cut the collector off and weld the pipe directly to the header. No more clearance problems or leaks.
    Edit: I paid $80 for mine. I like them, they are fairly good quality. The tubes run a good distance away from the starter solenoid to help avoid heat problems.
  4. J.R.
    J.R. Guest
    i had a set in my k5 with a 454 and had no problems with fit or clearence.
  5. bottomfeeder
    bottomfeeder 1/2 ton status
    Mar 9, 2004
    277
    Oklahoma City
    I have a coated set on my 77 K5 350. I have some leak issues, but nothing major.
    /forums/images/graemlins/waytogo.gif
  6. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    I had the same collector problem but i let it self clearance on my 1st trip out. now it is good to go /forums/images/graemlins/thumb.gif
  7. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    ive got a set of coated ones on my '91. i like em, except for that shackle bolt interfearance mentioned above. had to cut the bolts pretty short so they dont hit the header.
    i also found out today that my drivers side exhaust support has broken off, so the entire exhaust system has been hanging by the header.
  8. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i have 2 sets, one coated set on my 69 & one non-coated ones that i cut up to make work on my caddy eng.
    i like them fairly well. they are really good when u factor in the price, prolly best deal in headers.
  9. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    how low do then hang below the frame?
  10. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    on mine the bottom of the header is even w/ the bottom of the rear shackle.
  11. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i want to get a cheap used pair and cut out a bit to try to keep it above the lower flange
