E-Brake and Shackle Flip Question
Discussion in 'The Garage' started by gstuck3, Feb 10, 2006.
  1. gstuck3
    gstuck3 Registered Member
    Mar 15, 2005
    51
    Twentynine Palms, CA
    I did a 4 inch shackle flip on my '74 Jimmy, 350 / 350 / 203 / 12b / d44 and now my springs touch the e-brake cables that go to the backing plate. The cables are below the springs right now. This looks like it will limit axel drop. Should the cables be on top of the springs or below them. I'm putting in some degree shims right now and it's a perfect time to fix it.
    George
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    You can see how mine are here.
    and here
    Mine go under and I had the axle at full droop while the frame was on jackstands and they did not bind up.
    Ira
