e-brake cable on 14bolt rear disc con.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DERBINATOR, Jan 4, 2002.
  1. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    How will the stock blazer e-brake cables hook to the caddy calipers when doing a 14 bolt swap with disc brakes using the caddy calipers? What kind of mods need to be done?
  2. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    hey, im ready for those brackets like now! how come your brackets are $100 and misfits are $65??? anyway, with my caddy calipers i just cut my stock cables right at the end of the cable where the lead or metal piece starts that connects to the internals of the factory drum. then i just pulled them through the caddy cable stop brackets ( even the caddy bracket holes were the right size for the stock cable-end that snapped into the stock backing plate) then i pulled the actual cable through the spring and e-brake arm and used little tiny cable stop u-bolts to secure it and it wroked perfect, never had a problem. you can also use the lead cable stops with a crimping tool but then that would be permanent. e- mail me about those brackets again, i need them. thx j.c.
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I haven't tried the other suggestion. I am having new cables made. I'll give you the company if you need it.....
    Dave
    Horn Broken... Watch For Finger.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  4. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    this conversion was completely on my k5 a LOOOOONG time ago, but I've never hooked up the e-brake (and I need to do that cuz I have a manul... [​IMG] LOL)... great info here!
    anyway is misfit making is baking plates again??? I've seen his plates, and they are awesome!!! I'd like to see if he makes em for a 10b also...
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    I know why these brackets are $35 more than misfits: DERBINATOR makes the spacers out of one-piece aluminum, not like those individual spacers like misfit's.
    Check out this The K30 Collection
