E-brake cables (79 14 bolt to 87 K5 style)
Discussion in 'Parts & Trucks Wanted' started by BigOrange90Jimmy, Jul 8, 2003.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I am in need of the e-brake cables that will allow me to run my 14 bolt in my 87 K5. I would use my 10b cables, but I don't think they work. I have the 13"x2.5" drums out back. Let me know whatcha got!
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i think you need either 81-up or 85-up cables from 14 bolt to make that work, but if not then i have 77 ones probably
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Close. /forums/images/graemlins/wink.gif The correct year split is '83. '82 and older have the same length cables while '83 and newer have a longer cable running from the passenger side to the driver side. /forums/images/graemlins/thumb.gif
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    I've got a complete set of take-offs of drum brakes, backing plates, hardware and new shoes from a 1.25 ton M1008 ready to bolt on and accept new brake cables that will work exactly for your year. $100 for both sets. /forums/images/graemlins/thumb.gif
  5. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    i got a set of rear brake drums and backing plates from a m1008 what do i need to do to put them on my 79 the ebrake cables on my 79 will not work with them ?
  6. edeslaur1
    edeslaur1 1/2 ton status
    Jun 23, 2003
    193
    Oregon City, OR, 97045
    Using a '75 C14 in my 88K5, I was able to reuse the side-pull (not center-pull) e-brake cables in my K5 w/ the C14.
    You have to modify how the cable goes into the backing plate for the angle and then squeeze the clip that retains the cable end closed a bit more since the 1/2T cable end is smaller.
    Took me a couple of hours to figure it out, but it's worked great the last 3 years. I can't stand not having an e-brake.
    Or you can spend $$$. /forums/images/graemlins/smile.gif /forums/images/graemlins/k5.gif
