E-Brake cables - swapping from 12 bolt to 10 bolt?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BadDog, Mar 12, 2004.
  1. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    We just finally got around to installing the 10 bolt axle in my son's 77 K5 (the 3/4 ton axles didn't work out like we'd hoped). So, the 10 bolt has the late model cross-over e-brake cables and the truck is rigged for the older parallel cables that cross further up.
    Question is, what is the best way to fix the e-brakes? Haven't looked at them yet, but will the 12 bolt e-brakes transfer to the 10 bolt backing plates? Or would I be better off to convert the truck to the later style e-brakes (I've got most of the parts). I'm hoping I can just swap the cable stubs at the backing plate because I would really like to use the 10 bolt cables to fix the e-brakes on my 1 ton K5...
    Sorry for the newbie question but I'm pretty clueless when it comes to interchange on late model (as in 10 bolt) half ton stuff...
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    They should interchange both ways. You can also bolt you 12 bolt stuff on the 10 and vice versa. Same backing plate.
    Hope it helps.
    John
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    That's what I wanted to hear! Thanks! /forums/images/graemlins/bow.gif
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ditto on what John said. 10 and 12 bolts share the same stuff. /forums/images/graemlins/waytogo.gif
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you need some more I have spare 12 bolt cables at home from a 73 pickup still attached to complete brakes. I put all my 10 bolt everything on my 12 bolt, actually we unbolted my brakes from axle and slid new axle under without even cracking open a brakeline /forums/images/graemlins/waytogo.gif Then it was just a matter of putting on backing plate bolts and brakelines under axle tabs.
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Thanks, but looks like I've got all I need. But that reminds me, I need to replace the rear section of hard line since the nut got chewed up.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Rear brake hardline? I got both sides off the 12 bolt. Their yours if you need em. Should be same as 10 bolt since my 10 bolt lines fit the 12 bolt tube like a glove. Same fittings too /forums/images/graemlins/waytogo.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What didn't work out about the 3/4 tons?
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Paul:
    Thanks for the offer, but the messed up line is on the body side of the rubber line. Had to resort to vice grips to get it apart. No big deal though, like $5 at that parts store, and I'm getting new flex line anyway.
    Tim:
    The 3/4 tons were supposed to be 4.10s and we got a great deal on them, but there were some issues. With the front there was a twisted off stud on the knuckle, external hubs, and the remains of a welded (scabbed) on booty fab truss. Then the rear turned out to have severe drum/brake damage needing a complete rebuild. And no inexpensive disk brake conversions, I'm a stickler for e-brakes that work. On top of that, my son's got nearly new 33 MTs on 15" 6 lugs. It was a close call to start with, but for 4.10s and 3/4s he was going to bite the bullet and eat the expense. That was before we found out they were 3.73s... /forums/images/graemlins/frown.gif Just not worth it to fool with them at that point...
