E-Brake cables with an axle swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mplogic, Jun 21, 2002.
  1. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    Sorry for the multiple posts, just ran into another glitch. The mounting for the e-brake cable is way different on my 89 10 bolt than the 14 bolt FF that came off a 77 3/4 ton longbed. Does anyone make adaptation kits or custom cables for this? I was thinking of maybe trying a factory cable off a newer 3/4 ton shortbed truck. What did you guys do to hook up your swapped in axles?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What's an E brake? I cut that stuff off a long time ago.
    If I want an E brake in the future, I'll buy Jesse's rear driveshaft with the one installed up by the transfer case.
  3. mplogic
    May 7, 2002
    263
    Phoenix, AZ
    Um, yea, the e-brake is that simple mechanism that keeps your truck from breaking your tiny park pin and rolling down a hill. /forums/images/icons/smile.gif Also a traction aid. Anyone out there hook up their e-brakes after the axle swap? /forums/images/icons/smile.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What's a park pin? *Tim wonders where the park pin is on his 465* /forums/images/icons/grin.gif
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Look for backing plates off either the 14FF or SF from '83 on up. They will have the correct holes for your e-brake cables. /forums/images/icons/wink.gif
  6. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Oh now I remember.Your the guy who pulled his drive shaft and had his truck roll down the driveway,across the road, into a ditch,and totaling the truck /forums/images/icons/ooo.gif
  7. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    E-brakes are good....in fact I'm looking into getting a mico lock so I can lock up the fronts for when I'm dead-manning. And so I can do some stupid burn outs /forums/images/icons/smile.gif
