e-brake cables
Discussion in 'Parts & Trucks Wanted' started by solowookie, Apr 18, 2002.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    need k5 ebrake cables - lost them when I went to rear disk brakes (don't ask), and I need them cuz I have a manual tranny.
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Which cables, and for what year?
  3. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Jeff,
    I recently got rear discs on my 76 K5. The e-brake cables were 5" too short after the conversion. I have a 4" suspension lift and 35's. If you want my stock cables, you can have 'em. But wouldn't they be too short for yours too?
  4. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    that's a good question... I will have to measure them off my other k5, and then see if they fit. if they do then I'll definitely take you up on that offer!
  5. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    Hey Jeff for whats its worth i use just simple cloathes line rope so i can run it through all the proper hooks and holes then remove and measure it the adjuster bolt will usually fix any slack i might have had in the string the ol saying of measure 2 cut once
    hope it helps
  6. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    thanks - that sounds pretty simple
