E-brake help on stock 14Bff with drums.
Discussion in 'The Garage' started by Chrisblazzer89, Mar 28, 2007.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    OK I have a stock 14Bff rear with drums under my 88 K5 what do I need make my E-brake work?
    I will need to but new e-brake cables be cause I never had any in the first place but do I just get stock E-brake cables for an 88 blazer and thats that?
    OH BTW I will also need to re routh the cable to the pedel will that be hard or is it like striaght forward?
  2. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
  3. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    can any one help me???
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Do a quick search. This is currently being discussed in several threads, which is probably why no one has responded to yours.
  5. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I did a search but all I found was threads on disk brake e-brakes
    I need to get the e-brake working on a stock 14BFF with drums under an 88 K5
  6. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    I have the same issue right now. I know that there are 2 ways the lines were run on the 14ff depending on year truck. See what you have and that will help a little.
  7. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    its fairly straight forward to do. you need the cable that runs from your pedal to about half way don your frame for an 88 k5. Then you need 14FF cables that will mate up to the bracket there. IIRC there are 2 or 3 different versions of the 14FF cables. One type bolts to the backing plates and the pass side cable is too short to cross over to the drivers side like your k5 originally had with its 10 bolt. The other type of 14FF cable has that annoying little clip type retainer where it goes through the backing plate and the pass side cable is longer to cross over to your stock e-brake connector on the drivers side. The 10 bolt cable may fit in this app but I don't remember.
    Hope this helps
  8. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I will go get a new cable for my k5 and i will get all the diff versions of the cable for the 14b then i will return the ones that dont work:D
