E-brake lever for El Dorado caliper
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Aug 16, 2002.
    I've got a 90 K5 and I came across a 14 bolt full floater that I'm rebuilding with a disk brake conversion. I bought the 76-78 El Dorado calipers from Napa (OUCH!!) but they came without the lever and spring mechanism for the emergency brake. Besides a scrap yard, where can I find the e-brake parts for the calipers, preferably new /forums/images/icons/smile.gif
  1. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    I'm pretty sure the only place you can find the ebrake lever and spring is from the junkyard.
    Purchase a complete caliper(s) at a salvage yard, strip the neccesay components, and turn them in to recover the core charge.
  2. dyeager535
    26,975
    I've compared them to 79-85 calipers, the e-brakes aren't interchangeable. You MIGHT want to ask a GM dealer if they can get them. Really doubt it, but you never know. Barring that, some type of Cadillac restoring company? (catalog, etc)
  3. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    Try your GM Parts dealer - that's where I got mine. I'm fortunate to have a good one here where the guys will help find stuff.
    Part numbers? /forums/images/icons/smile.gif
    L&R E-Brake Levers: 18060644, 18060645
    Return Springs: 18060030
    No guarantees that these will work for you, but the levers fit my calipers. I haven't attached the springs yet, as I don't yet have the cables, so don't know if it will work for sure. BTW, I paid about $18 for each lever and about $20 for each spring. Can't figure why the spring is more... /forums/images/icons/crazy.gif
    Hope this helps,
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    thank you for that info!
  5. 502Burban
    Jun 8, 2001
    379
    Southern California
    Glad to help, m j. /forums/images/icons/cool.gif
    Take care,
  6. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    My local cadillac dealer had mine. A little unknown fact about cadillac is they make and stock service parts for 20years! Federal law requires, and most brands (including all other GM brands) only stock for 10years. I bought the return springs, and levers for them. I believed they had those calipers until 1979....so you should be able to find them somewhere...
    BlazerMan
  7. dyeager535
    26,975
    Required, but enforced?
    Last I checked (2001 or prior) GM had already discontinued the rear window seal for the hard top's on our K5's. Maybe part number has/had changed, but I tried looking up the number for it from my '86 parts manual, and it came up as disoc'ed. Quite a few parts at the time weren't available anymore, and should have still been in stock. (It was all seals for the slider windows, topper, and doors/tail gate)
    Heck, its only 2002, and they probably made over a million K5's, you'd *think* if GM actually cared for their customers, (and I believe they don't anymore) they'd still stock all of this stuff....they are only outside that 10 year window by 1 year. But I guess the first time I got an AC Delco "replacement" part with "made in taiwan" on the box, I should have figured it out.
  8. Thanks 502Burb! I was hoping someone could come up with some part #'s /forums/images/icons/cool.gif I'll check with my local dealer and see if they can order them for me.
  9. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
  10. By the way, are these the only parts I need (besides the cable) to get the e-brake to work? If more parts are needed could you please post the part #'s as well. TIA!
  11. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    It's probably not enforced too well, but I've had good luck. I bought tailgate & door hinges, a rear gate seal, rear gate latches, rear seat material and a few other small parts....all within the past year, all were ordered. I had most of the part numbers from my '73 book and an '88 book. They do change those numbers alot, mabey you just had a bum dealer who didn't want to hit F9(well, it was A key, mabey not F9, but just one keystroke and he had a whole history for a particular number) and look up subsequent part numbers..
    What I really counldn't beleive was the cadillac dealer looking up and then ordering those caliper parts and having them show up the following week!
  12. 502Burban
    Jun 8, 2001
    379
    Southern California
    Glad to help. /forums/images/icons/smile.gif Those were the only parts that I can recall needing. My calipers came with the rubber washers/seals that go on the e-brake lever shaft, so didn't need those.
    I did need to get some nuts to hold the levers on the shafts, but they were just your standard staked locking nuts and I picked them up at the local hardware store.
    Good luck,
