e-brake light
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FatBoyBlazer, Mar 8, 2002.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    jammed on the e-brake in front of my buds house last night and my e-brake light came on......pulled the release and the brakes unlocked and the pedelcame up all the way but the light stayed on and sugestions..????
  2. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    There is a switch that your pedal arm contacts when it is all the way up that turns the light off. It is probably stuck(dirty, worn out).
  3. coloradoblazers
    coloradoblazers 1/2 ton status Premium Member
    Mar 2, 2001
    506
    WY
    drill a small hole in the pedel likage and then a small hole to the bottom of the dash. Attach a small spring and this will keep the contact from rubbing and the light from staying on.
