E-brake mounted on my 205 transfer-case
Discussion in 'The Garage' started by 1 FN HI K5, Jul 28, 2002.
  1. 1 FN HI K5
    1 FN HI K5 1/2 ton status
    Aug 7, 2001
    465
    Northern CA Out in the stick\'s
    I have had this in mind for over a year now and just about have it finished. All i need now is a 1350 yoke for my 205 transfer case.Let me know what you think.. Later
    community.webshots.com/photo/45024728/45024895fGxhfC <font color="red">1 FN HI K5 </font color>
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Very cool............... /forums/images/icons/tongue.gif
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Nice fab work. What brake caliper did you use and how is it actuated?
  4. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Brad,you have it mounted yet.If so get a pick of that bracket.I have wanted to do that as well.High Angle Driveline's T/C e-brake is too much cash.
  5. 1 FN HI K5
    Aug 7, 2001
    465
    I agree when i wanted to do this Jesse at high angle had just made one for the 205 and was asking $150.00 now i see he wants $269.00 that is to much. The great thing about the way i did mine is there is no mounting bracket.The holes line up on the transfer case. The caliper came of a porsche 914. Im going to use my original parking brake.And hopefully the cable as well. <font color="red"> 1 FN HI K5 </font color>
  6. 1 FN HI K5
    Aug 7, 2001
    465
    The caliper is off a 914 Porsche it is a hydraulic/machanical brake this works the same as any parking brake. I had to use a 1/2 inch longer bolt for the top hole and 4 1/2 inch long bolt for the bottom hole with a 2 1/2 inch pipe spacer. This must be a record for me when something works this nice with out having to modify any thing.. <font color="red"> 1 FN HI K5 </font color>
  7. Ricks76
    Ricks76 Newbie
    Apr 6, 2002
    4
    By your girlfriends house.
    FN HI K5 let my first say i want your truck thats one sweet ride. /forums/images/icons/cool.gif /forums/images/icons/cool.gif I have been wanting to do this as well High angle wants too much $$$ for there set up. I like that you do not have a bracket to mount yours. Can you email me a pic of the lower mount? /forums/images/icons/grin.gif Thanks
  8. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    What did you use for a rotor? Custom? Nice job by the way.
  9. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    dude...do you think you could come up with a write up on this? part numbers and necessary hardware to complete this mod....please /forums/images/icons/grin.gif
    i want to do this to mine also...and the way the caliper is mounted it would give me more 'head room' to push the t-case higher toward the floorboard for a flatter belly pan.
  10. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I second that, I am VERY interested in this. If you could make the custom bits for sale I would be interested in that as well, but a write up would be just as cool. High Angle's is way too spendy for me. If the price for the High Angle kit was about the same price as going with Caddy calipers on the 14b FF rear disc vs standard calipers then they would probably sell them all day long... </font color>
  11. 1 FN HI K5
    Aug 7, 2001
    465
    Im not very good at write up's if someone else wanted to do that would be fine with me. Thanks <font color="red"> 1 FN HI K5 </font color>
  12. 1 FN HI K5
    Aug 7, 2001
    465
    Fill out your profile and i might send it to ya /forums/images/icons/grin.gif /forums/images/icons/grin.gif <font color="red"> 1 FN HI K5 </font color>
  13. MTPockets
    Feb 19, 2000
    502
    maybe you can tell us how/where to find the caliper and rotor. btw, how does the rotor mount to the back of the yoke?
    thanks
  14. 1 FN HI K5
    Aug 7, 2001
    465
    The rotor i had made at a local machine shop out of stainless steel. I just sent the money off for a 1350 yoke for the 205 transfer-case and i will bolt the rotor through the yoke where the strap's go to hold the u-joint with grade 8 bolts.As for the caliper maybe a junkyard.I was told one off a VW (Scirocco) --I think that's how it's spelled-- will work as well. <font color="red">1 FN HI K5 </font color>
  15. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    My kit is an add on to our 1350 c/v and can get a bit spendy because its a whole system- but you do get a discount for being a member- Jess
  16. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Jess, any chance that you'll make one that doesn't require a CV? I have a SWB pickup so a CV shaft is really not neccessary for me. Maybe it won't work with a regular u-joint yoke, but that's probably the only way that I could justify the cost. </font color>
  17. drivelineman
    Aug 23, 2000
    707
    You have to use our flange with our system- and you can run it without a c/v and it is less expensive that way- but most flanges that will bolt to our flange configuration are max angle 20 -25 degree's so take that into account- thanks for the question- Jess
  18. Ricks76
    Ricks76 Newbie
    Apr 6, 2002
    4
    Sorry i been working out of town and havent had time to read very many post. Sent ya a PM I would like to put the transfer case E-brake on my rig. What did it cost you compared to the one jesse has at High angle driveline?
    I like how your's is stuck right behind the transfer case and doesnt stick up to high. Thanks /forums/images/icons/smile.gif
