E-Brake Pedal cable pull through
Discussion in 'The Garage' started by rcamacho, Feb 7, 2006.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Believe it or not, the cable pulled through the clevis that is part of the pedal assembly. I'm thinking of welding up the material a bit and then grinding it to just slip the cable back through. Anyone ever have this problem?
    It seems my truck is cursed when it comes to the e-brake system. I've had to replace every piece of the brake cables due to the cables degrading and catching internally. Additionally, the PO set up the rear calipers incorrectly so the cables could not get a direct pull - which I've since fixed by rotating them to a vertical position.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I modified a multi-pump ratcheting pedal from a Caddy for mine. Instead of a single push, you pump the pedal two or three times. It's easier to get max tension on the cables since the pedal has a much lower gear ratio. :)
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
    I was able to weld up the clevis and tighten up the clearances again after a bit of finish grinding. A few of the pivot rivets were loose as well - a little spot weld did the trick. Not bad for my 2nd applied welding job. :)
