E brake
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cegusman, Jan 3, 2002.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I just put a 4" rough country lift on my k5, and swaped in a 14 bolt ff, The e brake cable is to short. What does everyone use to solve this problem.
    Houston, TX
  2. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Anyone?
    Houston, TX
  3. blazentank
    blazentank 1/2 ton status
    Apr 18, 2001
    426
    Houston, Texas
    What part of houston do you live in. I live in tomball tx it is a small town in north houston.
    "When you say i drive a fullsize are you calling my wife fat."
    J/K i was bored and made that up i don't even have wife i'am only 17.
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I just have a 10-bolt, but with my 4" RC spring lift my e-brake cable was interfering with my springs when trying to go under it as factory setup was. I simply re-routed mine to go through the spring. That little extra bit helped me.
    You should also have an adjuster in the middle of it right about the middle of the cab or so. Have you tried letting out the salck there first?
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  5. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I live out near katy
    Houston, TX
  6. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Anybody, I need help.
    Houston, TX
