e-brake ?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by harry, Feb 13, 2002.
  1. harry
    harry 1/2 ton status
    Feb 9, 2001
    106
    san diego, CA
    Does anybody have pictures I could see of our e-brake system (under the body I am trying to see the hangers). I took my blazer down to the frame amd am now putting it back together and don't know if I'm missing anything. I looked at my friends 1970 K20 and it seem to be a different set up
    harry
    69k5
  2. ed rex
    ed rex Registered Member
    Oct 10, 2001
    63
    Penn Valley, CA
    Hi Harry,
    Sorry, I don't have pics but it is really not too rough. The main cable comes from the front of the vehicle and terminates with a long screw. Attached to the very end is a spring which attches to a tab on the underside of the 'bed'. A piece of metal 'folded' to make a channel slides on the threaded portion of the end of the main cable and is adjusted by a nut that threads onto the threaded portion of the main cable. Through this channel is another piece of cable about oh...30" long. To both ends of this piece of cable, the cables from your brake drums are connected via a kind of 'C' shaped piece of metal. Now, additional springs are used to hold the whole assembly up and away from the driveshaft/transfer case output area. With a body and suspension lift, I fiddled with the placement of mine to ensure that a limp dangling cable would not wrap around the driveline.
    Sorry for the criptic description. Hope it points you in the right direction.
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    The intermediate cable should be suspended on the passenger side above the rear driveshaft by a hook that is at roughly the same angle as the forward cable/adjuster screw. There should be one shorter hook (about 3" long) attached to the frame rails on either side of the Blazer to support the two rear parking brake calbes, about a foot in front of where their housings are clipped into their brackets on the frame.
