E4OD tranny question
Discussion in 'Other Rides' started by thezentree, Feb 9, 2004.
  1. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    any of yall out there have an F-150 4x4? a friend of mine just got a '94 and we took it out on the beach the other day. we spent probably 2 hours out there, just messin around (and being good 'wheelers - we cleaned it up a little). anyway, we never really wheeled hard at all. on the way back out, he stopped cause he smelled something, and he thought it was maybe an exhaust leak. nope, ATF on the hot exhaust. it was spewing out of the front seal and out of that little rubber seal thing on the bottom. is this normal? another friend's dad is a tranny guy, we called him and he said that these trannies do that when they overheat, cause the front seal is weak. but 6 quarts?! /forums/images/graemlins/yikes.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    ford trannies, especially the AOD and E4OD seem to enjoy puking front pump seals..
  3. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    and the 4r100, Ford transmissons are almost as bad as chrystler motors.
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Once the seal is fried it will continue to puke until it gets fixed. I have rebuilt/replaced the E4OD several times before I got it right. Not a great tranny but can be upgraded if you spend some $$$ /forums/images/graemlins/yikes.gif
  5. kennyw
    Jun 9, 2002
    13,224
    94
  6. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Ford had a problem with torque converters with these. I had to change a few when i wrenched their. Torque converter would shudder and shake. It would wear out the seal.
  7. 99firehawk
    Dec 15, 2002
    491
    "Torque converter would shudder and shake. It would wear out the seal. "
    NOt to mention come apart and sound like a handfull of bolts rolling around in it.
