early small block late model heads ?
Discussion in 'The Garage' started by willy s wagon, Dec 8, 2002.
  1. willy s wagon
    willy s wagon Registered Member
    May 28, 2002
    20
    craig, CO.
    /forums/images/graemlins/confused.gifI have an early small block,(66-67 small journal 327)w/10:1 flattops and small valve, small chamber heads,(1.72-1.30, 60cc's).I also have a set of late model heads(centerbolts)are these heads compatible w/ the early small blocks.I have an intake for the late model heads already, and the short block is fresh, or should I just find another set of heads. /forums/images/graemlins/ears.gif
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    If you notch/redrill the center holes on the intake, it will fit on either heads /forums/images/graemlins/grin.gif
    Assuming they're TBI heads, they will have larger chambers and less power. If they're from a 305, the valves will be about the same size - only if they're 350 heads will they be larger.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Yes the heads will bolt up and work on the early engine. You said you have the intake manifold to match the later heads so you are good there, but you must use the guided rocker arms on the late model heads. The late model heads do not have the rectangular push rod holes to center the rocker arms like the early heads have.
  4. willy s wagon
    May 28, 2002
    20
    craig, CO.
    Thank you for your reply. The heads are off a 350 and I am actually trying to lower the compression ratio to avoid the pre-detonation (pinging) that I'm suffering from now.Lower power is no problem w/4:88 gears and a 465 trans. /forums/images/graemlins/thumb.gif
  5. willy s wagon
    May 28, 2002
    20
    craig, CO.
    Thank's again, I forgot to add, I do have the guided rockers.I didn't know about the difference between these and the early model ones. Thats why I come to this board for really technical questions! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
