EARLY vs. LATE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevy4x4, Jun 18, 2000.
  1. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    Do you guys think early model blazers and jiimies are better then later models?? I mean from like 73-81 or 82 vs. 82-91. The earlier models seem to be tougher then the late. I haven t seen a lot of late model blazers and jiimies built for hard core off-roading. What do you think??
    [​IMG]chevy4x4[​IMG]
    http://4x4.coloradok5.com
  2. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I've had both and think they're overall pretty much equal. The early models do have a few advantages such as cast iron t-cases, dana 44's and 12 bolts(though they're only marginally better than 10 bolts.) You've gotta love the 69-75's best with their fully removable tops!
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    The 73-80 trucks are built for ruggedness, while the 81-91 trucks have more luxuries(sp?).
    http://www.blazer.coloradok5.com is now under construction[​IMG]
    YEEEE HAWWWW[​IMG]
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The later model trucks, in my opinion, are better overall. The fuel injected engines have more power, get better mileage, and work better off-road (especially on hills and slopes). The later transmissions and transfer cases also have better overall gearing, which allows better acceleration and works better off-road. For comparison, take an '70's truck with a turbo 350 (2.5:1 1st gear) trans and 205 (1.98:1 low) case vs. an late '80's with an 700r4 (3.06:1 1st gear) and 241 (2.72:1) case. Assuming both trucks have the same 3.73 axle ratio, the overall gearing in low range of the early truck is only around 18:1 while the later truck has a ratio of 30:1.....that's a huge difference. Plus the overdrive makes highway cruising effortless.
    My vote is for the newer trucks, especially the '89-'91 K5's.
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    First Generation K5/Blazer is the BEST!!!!!!69-72(I prefer the 72 all the bugs were worked out by then)
    I can't belive I missed this tread [​IMG]
    Can't beat the classic look with a full convertable top!
    Oh ya and a 104" wheel base makes for an awsome wheeler.
    AMERICAN STEEL!!! Yeeeeee Haawwwwww [​IMG]
    As you can tell I love my rig and when I die I have insrtucted my wife to take my ashes and fire up my rig with the air cleaner off and rev it up to 5000rpm and dump me in!! Then leave it parked for the rest of her days[​IMG]....................
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  6. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Most early Blazers you will find will have beat interiors, very rough, maybe lots of rust stuff like that. Its up to you to cozy it up. Stock wise, the older were a bit tougher, I'm talking pre 81. They came with the 12bolt rear vs. the 10Bolt, NP203 or 205 vs the 208 or 241, TH350 vs the 700R4 (early 700's had lots of problems, it was all fixed up in 87' though). I agree about the new Blazers, say 87-91 are better b/c of TBI, but don't be getting jealous when you see a big badass FULLconvertible 1975 Blazer pull up next you. But the decision is up to you, the correct answer to your question is ALL Blazers 69-91 are the BEST!
    Boss
  7. 87Blzr
    87Blzr 1/2 ton status
    May 24, 2000
    111
    I like to own the 87 and newer because of the added comfort, gearing as explained earlier, and fuel injection is the best off road over a carb no matter what a carb guy says. And since mine is mostly a daily driver that I take to work and like to have the top off I like the half cap because if I get caught in the rain I don't get wet. However when I see the older ones I love those also, they look great but the newer suits me better for my needs.
    87 K5 Siverado, 68 SS 396 Camaro
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have an 82 and I have to say it has been the strongest Jimmy I have seen. It has been through hell and back and keeps beggin for more!
    So my votes are for around those years.
    Mike [​IMG]
    1982 GMC Jimmy - <font color=green>Emmett</font color=green>
    http://emmett.coloradok5.com
  9. Burt4x4
    6,854
    No way, FI over a good ol carb, no way!
    Ok so you can run your FI at a more than vertical angle but by then I would think the rig is gonna roll anyway.
    That is the only thing FI has over a carb is the ability to run at almost upside down angels, and I want my engine do do this cuz......?????...I don't know.
    Now a good Ol Qjet that has a few improvements will run at extream angles before the rig will roll AND IF it has a problem a feild repair can be made and your on your way!! as for FI.......????........Cell phone mabie the best thing to have.
    I love my 4barrel and wouldn't trade it for FI even if it was free!
  10. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    I concur with emmet, I have an 83 that I drive with my foot all the way down on the gas or all the way down on the brake...and she just chuggs along over whatever. so 83's my vote
  11. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    All K5 Blazer's KICK ASS!
    Remember-
    It's not what you buy, it's what you build!
    Shawn
    87 K5
  12. 87Blzr
    May 24, 2000
    111
    Ok Burt4x4, good post. I was always for a carb until I had FI. I loved the carbs I had but they required more attention than the FI. I bought my truck with around 100k and now have 178k and have yet to touch the TBI. No carb I had so far was that good. I realize a good Qjet can go at extreme angles but it seems only for a short period of time. Spending minutes going up or down a hill at a good angle seems to disrupt the carbs. Maybe I never had one that was in real good shape so I am not disagreeing with you, just never had the experience of a good carb I guess. My 396 Camaro has a brand new Edelbrock 750 out of the box and I also got the calibration kit to go with it and I still can't seem to get it how I want before all this. I am by no means a expert but this stuff isn't new to me either. Maybe when the FI s*^ts the bed and leaves me stranded it the pit I'll change my attitude but so far its been wonderfully reliable, requires little to no maintainence, and has great drivability. I do like carbs but just not as much since I have had FI. I did expect some harsh remarks saying what I did with the amount of people here with older non FI Blazers. Each have their good points and bad and we all have had our own good and bad experiences with both, or at least one, so I can also say what I think and can't really argue when someone gives their opinion also because they have had their own experiences. I actually expected more harshness even though thats not what I was after. By the way I checked out your Blazer and it looks like its ready for some action. I really like the rollbar design, looks really good with that body style
  13. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    Hmmm....usually around here I see way more older blazers (76ish-80ish) built bigger...not many big 89-91..but when I do see those they're usually huge. a blazer is a blazer in my book, except the really old ones like burt is defending...they're a different blazer catagory. but anyway, I like my throttle body injection....it was pretty cool to still have my blazer running while upside down when I rolled it, suprising...but cool...in an odd kinda way.
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  14. Burt4x4
    6,854
    I agree 87Blzr, well put!![​IMG]
    I have never had an off-road viehicle with FI, so I have no direct experiance with perfomance and or reliabiity with FI units. I am glad to hear that the reliability is high cuz if a fellow K5er is on the trail with a dead FI, I wouldn't know how to help him except hand him a cell phone and say "will this help"[​IMG].
    I hear ya about the tunning and tweeaking factor, Thats one thing I love about the Qjet it seams to hold it's tune for a long time once you find the right mix of air & fuel.
    Have a good one
  15. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Any K5 is cool. I like the 89-91 most but thats what i got. I like them all though and the FI is pretty good. You can get a bunch of stuff from Turbo City for it for under $200 and make it way better.
  16. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    As far as toughness, they are all about the same. You see more built older ones, because people always hack on the older stuff first, it's dollars and cents.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  17. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    I have a 90 K5 but I would say that the older ones are the best I thank they are built tuffer and get this the whole top comes off even with out a grinder HeHe I mean I love my 90 but I really want a 72
    [​IMG]Go prepared
    </font color=red>90 k5 soon to be big, bad, and mean
  18. 72Blazerod
    72Blazerod 1/2 ton status
    May 18, 2000
    264
    Vancouver, British Columbia, Canada
    Well Guys,
    As you can tell by my nickname, I like the first generation the best, but if I had to make a choice from 73-91, I would say both. I would like to take the tub from a full covertible 73-75 and keep the SM465 and NP205 but swap the fuel injected 350 and sweet, sweet front clip from a 91. I think with this you could possibly have the best of both worlds!!! Well those are my two bits (Make it easy on yourself and buy a 72).
    72Blazerod
  19. chaka73
    chaka73 1/2 ton status
    377
    Southern California
  20. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    Hmmmmm, good question grasshopper. Let us review.
    Early (gen2): Bad: rust, really really bad rust; hmmm. That seems to cover it. Good: Great looks; heavier ga. steel (what's left of it); full removable top; easy to find parts; all the stuff the others said about the mechanicals.
    Late: Bad: not as appealing, 1/2 top, lighter steel.
    Good: less rust, priced as "old chevy truck" rather than collectible caliber (so far).
    I personnaly prefer gen 1.
    Good luck!
    You can't beat going Topless!
