Easiest way to fit my new Fodeez!
Discussion in 'The Garage' started by cok5, Oct 4, 2005.
  1. cok5
    cok5 Registered Member
    Apr 27, 2004
    89
    OK, I am new to the K5 scene and wondering on my options to lift this thing to fit my new Fodeez. Sorry for the newbness!
    I have read about the 52" front spring swap and then doing the shackle flip in the rear. I am positive my lift will include a DIY4x4 shackle flip and some fender trimming. What would be my best bet (as far as springs) and cheapest to get these tires under it. I don't want to completely hack my fenders up but don't mind trimming some. I also know that a big lift spring will not flex as well.
    I just want some real world experience on what you guys are running, my tires are 39.5" TSL's. Thanks
  2. outlawtorn
    outlawtorn 1/2 ton status
    Jul 21, 2004
    365
    Box Elder, SD
    Youll need to do alot more then just trim with only a shackle flip and the 52 swap... thats about 4 or 5 inches of lift and youll need to do alot of intense fender hacking not trimming to fit those 40's. Theres alot of people on here running 40s and that small of lift, im sure they'll chime in.
  3. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    here is my rig with 39.5 TSLs...
    thats about 5" of suspension lift (4" + 1" zero rate up front, shackle flip plus zero rate in back....) and a 1" body lift plus trimming. I am in the process of lowering my truck down to 4" (shackle flip, 52s up front) right now. IMO, 4-5" is the perfect amount to lift one of these rigs. Just fender trim until stuff fits. If you want the result to be bling, mark how you want them trimmed and have a body shop do it for you, they can put a factory lip on the edge and everything... I ain't rich so I just cut it.
    j
  4. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    What the hell are are "Fodeez"? Tires???
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    X2 :rolleyes:
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I think he meant to say 40's. Speak Engrish, we're kinda slow. :D
  7. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    well lets put it this way....you have fodee toes. :D
  8. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    I googled for Fodeez. I found a few references to majuana, Some 4x4 stuff, Music, And Beer.
  9. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    'fodeez' would be 'fourties' which would stand for 40" tires
    keep on chevyin
  10. cok5
    Apr 27, 2004
    89
    Oh my god.......Fodeez would be of the Superous Swamperous bigus tirus family. 39.5" at the top of the head exactly. One heck of an animal with a nasty bite. Not quite as bad as there close brother the Superous Swamperous nastiness boggerous. :D Thanks allot Jekbrown, awesome rig. It does not appear that you really trimmed your fenders allot. Do you still have inner fenders in front? What springs are you running front/rear?
    Anybody else?
  11. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    ~ 6" of lift
    4" springs in front with a zero rate (plus a little extra height from the D60 perches)
    4" shackle flip in rear plus a 2" a-a-l.
    To run 40's with not much lift and not have them rub, major fender trimming is required. I do still have my inners but I pushed the rear of the inner up against the firewall and bolted it there.
  12. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    HA HA hA
    This thread is cracking me up. E-fordee
    Anyway yes you have to do some trimming. No hacking. Seriously though look at the tiny bit of flare your fenders do have stock, about an inch. I pretty much cut on the flare about 1.5". I used Yunit's pattern and adjusted to my liking. So far I can stuff the tires pretty well. The inner firewall will be the worst spot.
    Oh ya 39.5 tsl with 4" front springs o-rate, haven't even moved it forward 1.5" yet and it barly rubs when stuffed hard and turning, el cheapo shackle flip with 0-rate moving the axle 1.5". 5" lift.
    Jesse
  13. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,023
    849
    Pinckney, MI
    Sorry To Hijack but why is there a Stick hanging out the back of your rig?? :dunno: :what:
  14. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Mudhole Depth Guage :laugh:
  15. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    Same 4" + 1" + 39.5" TSL's.
    Just a little trimming, front diff moved 1.25" forward and I still have inners up front (barely.)
    Rene
  16. k5blazin
    k5blazin 1/2 ton status
    Dec 19, 2004
    262
    Elizabethtown, PA
    Couldnt you just do a 8in sus. lift to fit 39.5's? i am wondering because that is what size tire i had in mind to put under my k5.
  17. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    You could, but your center of gravity will be higher, and you won't get near as good of flex or ride.
  18. k5blazin
    Dec 19, 2004
    262
    Elizabethtown, PA
    oh i see. thanx for the help.
  19. cok5
    Apr 27, 2004
    89
    tRusty that is a cool looking rig. I really like the flat black look. So the consensus seems to be 4" plus O-rate in front and shackle flip in rear and 0-rate. Right?
    Heck I would not even mind throwing a 1" puck in there.
    I figured I would see more guys with 52's in the front.
  20. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    You would still have to do some trimming with a 8in lift.
