Easiest way to remove the D44 axles
Discussion in 'The Garage' started by 80blackgmc, Nov 23, 2004.
  1. 80blackgmc
    80blackgmc Registered Member
    Nov 21, 2004
    43
    Hey guys. I found two Dana44 diffs at the local boneyard today, but they are 6 bolt trucks, mine is an 8 bolt. I think the axles from the two interchange.
    What is the easiest way for me to pull the axles only at the boneyard? Any special sockets/tools I need to take the brakes off the diff? Sorry, I am new to this 4x4 stuff. Thanks.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You will need snap ring pliers, a hub socket, a hammer, and some sockets. You have to pull off the locking hub, caliper, hub/rotor assembly, spindle (where you will need the hammer). Then they will just slide out. Bring a block of wood if you want to take the spindle as well so you don't mess it up with the hammer.
  3. 80blackgmc
    Nov 21, 2004
    43
    Thanks a LOT!
