Easiest way to replace motor mounts?
Discussion in 'The Garage' started by Lotsa_Faith, Jan 2, 2003.
  1. Lotsa_Faith
    Lotsa_Faith 1/2 ton status
    Jul 10, 2001
    474
    Mckinney, Texas
    How do yall go about replacing your motor mounts?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I jack up the motor and secure it with a block of wood or something and then I go to it. You can get the motor up pretty high. Oh yeah, you want to undo the two big motor mount bolts before you jack it up. but I guess thats a gimmee.
  3. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    If its the clam shell style, dont throw out the shell around the blew out ENGINE mount. You probably have to drill out the rivets if its stock. Dont mix up the alignment to ensure proper installation of the new mounts. The new mounts should come with zip ties in place of the rivets. Good Luck /forums/images/graemlins/eek.gif! /forums/images/graemlins/burb.gif
  4. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    It's pretty simple you might wanna go with poly mounts, maybe a nice purdy orange red and paint the mounts the same color while your at it, while you have the out..... /forums/images/graemlins/thumb.gif
