easiest way to tell between a d60 and d70
Discussion in 'The Garage' started by muddyblzr, May 15, 2005.
  1. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    hey quick question for a friend what is the easiest way to tell a rear dana 60 from a dana 70?
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Usually the webbing at the chunk is a good identifier but since your buddy is not familiar than look for the casting marks in the lower right web corner when you are facing the diff cover. MOST of the time it will tell you what model it is but not always.
    Just some guide lines:
    "B" series D70's usually have a large B casted on top of the pinion channel of the chunk.
    HD D70's are just stout as can be and look like they are on steriods - even id you are not familiar with axles a HD 70 will look beefier than others.
    "U" series D70's are very smooth on the bottom and almost round in shape on the bottom side.
    If still in question post up a pic for your buddy and we'll do what we can to help .
    HTH . Tom
  3. muddyblzr
    Nov 2, 2004
    623
    alright thanks i think the info u gave will do him good
    thanks again if he cant figure it out ill get him 2 send over a picture
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    The best way yo tell if it is a desireable 70 is to pull a shaft.It should be 1.5" 35 spline.A BOM can help out alot too.Mine did not have a BOM but it wasnt that big of a deal to get parts.Best I can tell mine is out of a 73 Dodge D or W300 :D
    Chris
