easily adjustable drag link
Discussion in 'OffRoad Design' started by prjt_blzr, Jun 20, 2003.
  1. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    Steve,
    I'm looking to soon be running one of your drag links when my D60 gets back and I have a question. I like the idea of the bent link to clear the crossmember and the angles that the TREs run at because of this. But not having easy or precise adjustment is a bit bothersome. Would it be possible to thread the outside of the 1.25" tubing and the inside of the 1.5" tubing to make a link that is easily and finely adjusted? I would think the size of the tubing would provide plenty of beef and not be prone to failure. What do you think?
    Thanks,
    Mike
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Mike, I think it's possible but not something we can do easily. And to be honest, I'm not sure it's that necessary. The adjustment on the ends is as small as 1/18th of an inch so we've never had problems getting the steering wheel centered. Heck, the GM frames and springs will move around enough that it's not safe to assume you're axle is centered to within 1/18th of an inch! It can be a bit of a pain to adjust but it doesn't happen very often.
  3. prjt_blzr
    Mar 4, 2001
    352
    COS, CO
    Well, you sound pretty confident that the drag link will adjust to center the steering wheel. I'm used to adjusting the factory link in small increments and it sounds like the longer link is more forgiving. I guess I'll just take the pitman arm puller with me when I get the front end aligned.
    Thanks and I'll talk to ya soon for the drag link.
    Mike
